Bahasa/ Kosakata Montir
Moderator: Unta_item
Post Reply
Unta_item
Contact:
Post by Unta_item » 24 Dec 2012, 19:21
Kadang Kita Sering menjumpai penamaan suatu spare part yang ngak sesuai dengan namanya ....
ayuk dikumpulin biar buat pengetahuan semua ( no Offence)
Ane mulai ya, kalau ada yang nambah silahken,,,
1. Piston, = Seker, (daerah jawa tengah)
2. Bak verneling= Ndas Babi ( bhas jawa), totok Babi ( bhs jawa)
3. Joint Kopel= Kres Kopel ( bhs jawa)
4. Cutt off = Ketot (bhs jawa)
Lainnya Menyusul kalau pas ingat ........ :mky_02:
http://yamatoikwan.blogspot.com/
https://www.facebook.com/pages/Pojok-Un ... 0505942274
Kalau Bisa diperbaiki ya jangan diganti, Kalau bisa bikin sendiri mengapa harus beli ?
Re: Bahasa/ Kosakata Montir
Post by Turboman » 25 Dec 2012, 00:07
Laher = bearing
terot = Tie Rod
tali kipas = V belt
sekir (skuur) klep = membersihkan kerak di kepala katup intake
BADAK
Post by BADAK » 25 Dec 2012, 23:11
tengkorak :mrgreen: = Case diff / rumah gardan
stempet = grease / vet
as jantan = splin propeller shaft
siku gareng = bell crank
Live as if you'll die today
Unta_item
Contact:
Post by Unta_item » 26 Dec 2012, 17:02
Laker Kroncong = Lager Bambu ....
SM Moderator
SM Moderator
Post by y_anjasrana » 27 Dec 2012, 20:40
metal duduk = main bearing
metal jalan = round bearing
kruk as = crank shaft
dtx_100
Post by dtx_100 » 29 Dec 2012, 09:25
roda gila=roda gendeng=flywheel
dtx_100
Post by dtx_100 » 29 Dec 2012, 09:41
karet susu=front stopper. @ peli bebek=worm steer
BADAK
Post by BADAK » 29 Dec 2012, 11:55
Dudukan / pangkon mesin - engine mounting
As suling - shaft rocker arm
Kampas kopling - clutch disc
Matahari / dekrup - clutch cover
Mata yuyu - key chromesh
Sumpit klep - push rod
Burung klep / manukan - rocker arm
Snel - booster rem
As satelit - shaft pinion
Bantalan ampere - stator altenator
Bantalan starter - yoke starter
Cones - retainer
Unta_item
Contact:
Post by Unta_item » 01 Jan 2013, 21:50
diKonis / Di Popok = Diberi lapisan Las tembaga/ kuningan ( buat menambah daging ) :wkkk:
Post Reply
Return to “Out Off Topics (OOT)”
