Report serba serbi ReMap di B3bonk love FRD garage
Re: Report serba serbi ReMap di B3bonk love FRD garage
Post by Turboman » 19 Jul 2018, 10:20
Keren nih mobil baru en std aja dyno test
Mana nih yg udah pada ReMap......kok cuman ane en om ChZ aja yg dyno test
yg lain manaaaaaaa............
xtr40rd1n4rym4n
Post by xtr40rd1n4rym4n » 19 Jul 2018, 11:11
dyno begitu biasanya kena berapa om turbo?
Post by Turboman » 19 Jul 2018, 11:33
xtr40rd1n4rym4n wrote:dyno begitu biasanya kena berapa om turbo?
Kalo di Lestari kena 450 rb per 3X run
xtr40rd1n4rym4n
Post by xtr40rd1n4rym4n » 19 Jul 2018, 11:37
siap Om. makasih infonya...
:big_deal: :big_deal:
liemivan86
Post by liemivan86 » 20 Jul 2018, 02:47
Turboman wrote:Keren nih mobil baru en std aja dyno test
Err... Ini belum diapa2in kan? Kenapa di dyno om? Tadi nya saya pikir sudah di remap, pengen tau hasil nya..
Post by Turboman » 20 Jul 2018, 08:07
itu bukan mobil saya om
cuman ngeliat di Fb grup Cortez
PRBS
Post by PRBS » 20 Jul 2018, 08:36
liemivan86 wrote:
20 Jul 2018, 02:47
Mungkin nextnya mau naik stage 1.. jadi naik dyno dulu biar ada data before and afternya..
Post by ChZ » 20 Jul 2018, 10:22
PRBS wrote:
20 Jul 2018, 08:36
liemivan86 wrote:
20 Jul 2018, 02:47
Krn woolenk itu mobil resing... :ngacir: mungkin tar turun balap turing tuh woolenk...
"Yang musuhmu nggak akan dengerin penjelasanmu, yang cinta sama kamu nggak butuh dijelasin" - Sujiwo Tejo
cendoladem
Daily Vehicle: panther
Post by cendoladem » 21 Jul 2018, 02:01
om mau nanya dong, skrng vnt fortuner udah di dastek, cmn dpt 265hp,udah pakai pipe yg plong gak ada cc. Kl di remap lagi apa bisa tenaganya tambah? soalnya pernah liat vnt bisa sampe 295-300hp pakai dastek, entah fortun sy rendah tenaganya
Post by Turboman » 21 Jul 2018, 10:57
cendoladem wrote:om mau nanya dong, skrng vnt fortuner udah di dastek, cmn dpt 265hp,udah pakai pipe yg plong gak ada cc. Kl di remap lagi apa bisa tenaganya tambah? soalnya pernah liat vnt bisa sampe 295-300hp pakai dastek, entah fortun sy rendah tenaganya
ini VNT ya ?
om mau kejar Hp setinggi2 - nya dgn resiko maksimal (EGT melejit) atau resiko minimal ?
Kalo mau kejar Hp tinggi dgn resiko minimal, upayakan AFR jangan di bawah 1:16 (pasang EGT meter)
Kalo misal saya mau set VNT utk Power di atas 265, saya akan lakukan peningkatan air flow dulu :
- Ganti Turbo yg Flow lebih gede, pake G Turbo misal (Plug n Play ke 2KD VNT)
- Ganti Cam exhaust misal pake TJ Cam
- Poles intake manifold atau sekalian ganti intake pake BangMod (misal) supaya airflow lebih baik
- Klep2 periksa dan setel lagi
Muffler free flow
Tail pipe 2,5"
Belalai dr air filter box ke depan, atau sekalian bobok AF box dan bikin saluran extra ke depan
Piggyback boleh pake ECU Shop Monsmax
Matik pasang Trans Go (mencegah kopling selip) & ATF kasi yg bagus spt RP / Amsoil / RL
cendoladem
Post by cendoladem » 21 Jul 2018, 20:16
Turboman wrote:
21 Jul 2018, 10:57
ini VNT ya ?
Muffler free flow
Tail pipe 2,5"
di dastek kan dikasi 4 setting, maksudnya setting tertinggi aja dikasi hp paling tinggi, dipake hanya sekali2 aja. kalo harian pakai settingan yg rendah di nomer 2 atau 3. Tp bingungnya jg kl udah ada dastek apa dgn tune ecu ada effeknya dgn tune dr dasteknya?
soalnya mobil2 lain cmn dikasi dastek bisa dpt 285-300hp, 300hp mungkin jarang cmn 1-2 mobil, tp yg dpt 285-295hp banyak, dan ini tanpa ganti cam/turbo/stel klep. Mrk cmn ganti down pipe yg gak ada catalyc converternya doang sama ganti air filter. Utk setinggan tunenya mungkin mirip2. apa parameter ecu dr pabrik di mobil sy yg lain sendiri?
mesin diesel bisa di stel klep yah? dmn biasanya yg bisa stel klep ?
Post by marmut » 21 Jul 2018, 23:36
cendoladem wrote:
21 Jul 2018, 20:16
stel klep tidak ada hubungan dengan bensin atau diesel.
bahkan mesin yang menganut HLA pun perlu "disetel" setelah beberapa periode, apalagi jika pakai oli sembarangan sampai terjadi sludge.
pipes - cigars - coffee
Post by Turboman » 21 Jul 2018, 23:43
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 10:57
ini VNT ya ?
Muffler free flow
Tail pipe 2,5"
Kalo dgn Turbo std / Cam std sih jujur aja kalo mau aman Max 240 an Bhp (menurut saya pribadi dgn perbandingan 2KD kawan yg pake RHF4 hybrid dan Cam ganti, proper setting)
mobil om di set 265 bhp itu AFR nya 1 banding brp ?
Kalo utk Turbo std, AFR aman paling rich di 1:15 sebetulnya......inipun harus bantu monitor pake EGT meter
Tapi kalo di Indo ya byk yg nekat set AFR sampe 1:14 bahkan 1:13,5
kalo AFR sampe begini saya sih no komen dah.......buat yg percaya katanya aman ya silakan.......kalo saya pribadi mah gak mau AFR sampe di bawah 1:15 utk Turbo std
wkwkwkkwkwk
cendoladem
Post by cendoladem » 22 Jul 2018, 00:40
Turboman wrote:
21 Jul 2018, 23:43
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 10:57
ini VNT ya ?
Muffler free flow
Tail pipe 2,5"
wkwkwkkwkwk
waduh entah om, udah lama pasangnya, udah ampir 4 thn yg lalu. Sampai skrng sih kyknya gk ada apa2 di turbo ato mesin. Gak ada bunyi2 aneh,tenaga gak pernah ngempos ato cek engine. Bawanya mix antara bejek ama santai,cmn kebanyakan bejek sih.
cendoladem
Post by cendoladem » 22 Jul 2018, 01:27
Turboman wrote:
21 Jul 2018, 23:43
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 10:57
ini VNT ya ?
jadi kalo untuk vnt fortuner dgn remap ecu saja, max paling aman 240hp yah?
Pugman
Post by Pugman » 22 Jul 2018, 06:00
b8099ok wrote:
14 Jul 2018, 19:10
Chevyman wrote:
14 Jul 2018, 10:52
Apa kabar remap 2GD........
Sdh ada yg ambrol matik nya kah... ??
Ambrol sih nda om, cm hamil anggur aja.
Om tanya donk, kalau check engine keluar setelah dibaca isinya "Catalyst not balance".
Apa ini termasuk pincang ya?
Post by Turboman » 22 Jul 2018, 08:18
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 23:43
cendoladem wrote: di dastek kan dikasi 4 setting, maksudnya setting tertinggi aja dikasi hp paling tinggi, dipake hanya sekali2 aja. kalo harian pakai settingan yg rendah di nomer 2 atau 3. Tp bingungnya jg kl udah ada dastek apa dgn tune ecu ada effeknya dgn tune dr dasteknya?
wkwkwkkwkwk
Pasang EGT meter aja
Kalo probe di downpipe set buzzer di 600 - 610 deg C kalo mau aman
Post by Turboman » 22 Jul 2018, 08:23
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 23:43
cendoladem wrote: jadi kalo untuk vnt fortuner dgn remap ecu saja, max paling aman 240hp yah?
Hasil akhir tenaga sih bisa bervariasi, tapi kalo mau aman ya AFR jangan di bawah 1:15
Dan itupun WAJIB pasang EGT meter
Dan kalau mau benar2 aman banget AFR jangan di bawah 1:17
Pas Dyno run juga minta pake wideband lambda utk ukur AFR nya
Hasil akhir bervariasi tergantung modif exhaust / intake yg anda terapkan
Post by Turboman » 22 Jul 2018, 08:37
Nih 2KD VNT kalo mau maen agak extreme, tingkatkan dulu air flow nya (Kalo mau cara yg lebih proporsional & Optimal)
G Turbo pake Grunter aja cukup
Camshaft ganti misal pakai TJ Cam, ini akan berefek juga thd EGT (lower EGT ) & Turbo spool akan lebih cepat
Juga aplikasi Free flow muffler / Tail pipe 2,5" / belalai air filter bpx ke depan atau bobok AF box
Jadi misal set AFR nya ke 1:17 aja hasilnya udah dahsyat KARENA flow Turbo nya udah lebih gede
AFR sampe 1:16 ya boleh, tapi WAJIB pasang EGT meter
Pasang Trans Go supaya Matic lebih direct / gak selip kopling nya
Ini kalau dari Perspektif saya pribadi aja yah
* Bukan sales Turbo / Cam *
cendoladem
Post by cendoladem » 22 Jul 2018, 12:12
Turboman wrote:
21 Jul 2018, 23:43
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 10:57
ini VNT ya ?
Muffler free flow
Tail pipe 2,5"
wkwkwkkwkwk
nyari info ttg camshaft ini dimana yah? di google barusan minim info
Post by Turboman » 22 Jul 2018, 13:46
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 23:43
wkwkwkkwkwk
TJ Cam di Jkt yg jual di Alecon - Kelp Gading
cendoladem
Post by cendoladem » 23 Jul 2018, 20:09
Turboman wrote:
22 Jul 2018, 13:46
cendoladem wrote:
Turboman wrote:
21 Jul 2018, 23:43
wkwkwkkwkwk
mahal yak, sama ongkos pasang + tune ulang cmn naek 5-10hp
g3m1n1m4n
Daily Vehicle: Toyota Avanza
Post by g3m1n1m4n » 12 Aug 2018, 10:08
Akhirnya selesai juga baca thread padat ,bergizi dan menambah wawasan saya,terimakasih Om TS dan Om-Om yang sudah berbagi opini dan pengalamannya :emo-flowerforyou: :emo-flowerforyou:
singachu
Post by singachu » 30 Aug 2018, 09:40
Nunut thread :mky_01:
Nanya nih, fact or mitos.....
Informasi yang beredar :
* ECU bisa melakukan kompensasi / learning gaya mengemudi dan disimpan di ECU
* ECU bisa melakukan kompensasi terhadap oktan bensin yang diisikan dan disimpan di ECU
* kalau pingin isi oktan lebih tinggi / biar learning ECU nya lebih cepat menyesuaikan, maka hasil yang tersimpan di ECU dihapus dengan cara lepas kabel aki.
minta pencerahannya dong :mky_02:
regards,
singachu
b8099ok
SM Moderator
SM Moderator
Post by b8099ok » 30 Aug 2018, 19:00
singachu wrote:
30 Aug 2018, 09:40
regards,
singachu
Gaya mengemudi yak, dr cara injek gas, cara overtake, wot, etc.
Kompensasi thd oktan cm di bbrp jenis ecu saja. Disamping itu ada jg kompensasi latitude, ambient air, etc.
Cabut aki akan menghilangkan KAM (keep alive memory), tp tidak menghilangkan map engine basic. Yg di rubah dalam proses remap adalah map engine basic, jd ngga bakalan ilang. Klo ada yg jokul ecu tune tp cabut aki ilang, patut dipertanyakan IQ custnya.
Sampe saat ini msh ada koq yg cabut per pedal gas dibilang ecu tune, dan herannya msh ada aja customer yg percaya dan membelinya. Hellowwww, its 2018 brohhhhh,.... :snipersmile:
Tune and drive! :big_love:
Post Reply
