Report serba serbi ReMap di B3bonk love FRD garage
Post Reply
nicky
Daily Vehicle: Santa Fe CRDI
Re: Report serba serbi ReMap di B3bonk love FRD garage
Post by nicky » 26 May 2018, 23:53
Nainggolan21 wrote:
26 May 2018, 13:53
Ijin nyeletuk, saya punya 2 kd vnt, selalu pakai "SOLAR" dan sebelum setelah remap dengan gaya berkendara yang sama malah lebih irit ampe 2 km per liternya. Sekarang malah gak pernah lagi ngecek konsumsi BBM, yg penting gaspol aja. Toh Bekasi-malang-bromo-surabaya-madura-surabaya-bekasi hanya habis 750.000 buat Bahan Bakar :big_comfort:
Mau tanya donk,
2kd vnt di remap dapat berapa hp & torsinya om?
Jd minat nih.. :mky_01:
Nainggolan21
Daily Vehicle: Satria FU
Post by Nainggolan21 » 27 May 2018, 00:29
nicky wrote:
Nainggolan21 wrote:
26 May 2018, 13:53
Mau tanya donk,
Angka pasti saya gak tau om. Karena gak pernah di dyno. Tapi ANPS Dakar standart saya adu masih lewat sih. No offence yaImage
Berarti tenaga diatas 181 ps dan torsi diatas 400 N.m . Lebih pastinya kita tunggu aja si mbah yg jawab.
k0b0chan
Daily Vehicle: Anki
Post by k0b0chan » 27 May 2018, 00:33
Nainggolan21 wrote:
nicky wrote:
Nainggolan21 wrote:
26 May 2018, 13:53
Mau tanya donk,
Dyno dong om. Om turbo udah suruh dyno tuh
b8099ok
SM Moderator
SM Moderator
Post by b8099ok » 27 May 2018, 08:35
coklatMetalik wrote:
26 May 2018, 22:58
7K-E bs dibikin irit ndak mbah? Tapi performanya jangan dibikin loyo :mrgreen:
Duhh kok bisa ya ane kegoda racun ginian :frm_bang_head:
7K-E kyk pny berbi? Swap 1kd aja 😍😍😍😍😍
Tune and drive! :big_love:
Post by Turboman » 27 May 2018, 08:54
coklatMetalik wrote:7K-E bs dibikin irit ndak mbah? Tapi performanya jangan dibikin loyo :mrgreen:
gak ada OBD2 ?
harus pakai KTAG
laoshizaoan
Post by laoshizaoan » 27 May 2018, 09:42
Om bisa remap bmw F10 520d 2016 enggak? Sekalian egr delete. Thanks
adiputra4
Post by adiputra4 » 27 May 2018, 09:49
Mau tanya oom 2GR-FE dibikin lebih irit bs gak ya ?
Jalanan makin macet bensin berasa bgt borosnya.. mau tuker bpkb tp masih sayang sm mobilnya :big_dunno:
erwin95
Post by erwin95 » 27 May 2018, 09:54
26 May 2018, 22:58
Nah, untuk mobil injeksi lawas yg sistem injeksinya masih sederhana sekali, bahkan pengapiannya aja masih pakai delco, itu bisa di remap gak ya?
laoshizaoan
Post by laoshizaoan » 27 May 2018, 09:56
Om mau tanya bisa remap bmw F10 520d diesel 2016 enggak ya? Sekalian egr delete. Mksih
Post by Turboman » 27 May 2018, 11:30
26 May 2018, 22:58
Bisa
tapi parameter yg dimainkan terbatas.....krn gak bisa kontrol ignition / gak ada Oxygen sensor utk monitor AFR dgn precise
Kalo ReMap utk naekkin performance si bisa bangett
sy pernah liat ada yg ReMap Sipik Genio......pake KTAG utk read & write nya
coklatMetalik
Daily Vehicle: LGX
Post by coklatMetalik » 27 May 2018, 13:06
Portnya kyk begitu tuh, entah KTAG atau bukan tuh
Kalo swap engine jangan ah. Kalo Kijang isi kapnya bukan mesin K itu kyk ada yg kurang... :big_smoking:
1979 Datsun GN620
1992 Toyota KF40
2000 Toyota KF83
batumakam
Post by batumakam » 27 May 2018, 13:09
Soal remap ecu jadi inget kejadian minggu kemaren...
Lagi remap k360 sama k410 ditanya sama ownernya, bang bisa remap mobil saya nda? Lepas limiter dong..
Sampe sekarang pusing ntar kalo kesana mau jawab apa... :wkkk: :big_cat:
Ane suruh garasi frd aja ya? :ungg:
oh my.....
Rakean
Post by Rakean » 27 May 2018, 13:26
Truk cabe alumni bebonk :big_childish: :big_childish:
Nissan YD25DDTi VGS Turbo Diesel Intercooler (2016 - Present)
ginting
SM Moderator
SM Moderator
Post by ginting » 27 May 2018, 13:45
Rakean wrote:Truk cabe alumni bebonk :big_childish: :big_childish:
mantap, mbah...tiada gunung yg tak didaki si Hitler
maviacrazy
Post by maviacrazy » 27 May 2018, 15:15
Ijin gelar tiker dl di sini sambil ☕️.
Mau Bensin Atau Diesel Yang Penting Orangnya SEHAT DULU (amin YRA)
:emo-big_love: :mky_02: :big_love:
Post by Turboman » 27 May 2018, 15:23
Totok ECU
xtr40rd1n4rym4n
Post by xtr40rd1n4rym4n » 27 May 2018, 16:41
Ijin nyimak ya suhu bebonk 🙏🏼
:mky_02:
17Herdy
Daily Vehicle: Avanza
Post by 17Herdy » 27 May 2018, 18:21
Rakean wrote:
27 May 2018, 13:26
Makasih banyak om ane gak di cumiin.
Gemeteran ane k3 di jepit 4 dijel remapan.
:big_childish:
:emo-flowerforyou:
DeganEspero
Daily Vehicle: GE8
Post by DeganEspero » 27 May 2018, 18:29
Wah topik bahasannya seru
Ijin nanya om, kalo buat ECU kayak DIY kit dari Megasquirt gitu harus bikin base map dulu, parameternya apa aja ya om? Apa ada referensi" sprti buku" gitu buat ecu remapping?
Maap pertanyaannya nubie :mky_01:
Not everything that counts can be counted, and not everything that can be counted counts
b8099ok
SM Moderator
SM Moderator
Post by b8099ok » 27 May 2018, 18:32
Bmw need to see the ecu. Setau ane, ecu 7ke nda bisa. Klo 2GRFR sptnya bisa.
B064RT
Daily Vehicle: Escape
Post by B064RT » 27 May 2018, 18:38
maviacrazy wrote:
27 May 2018, 15:15
ola oom arief.... pa kabar? dah waras atau masih crazy?
Post by Turboman » 27 May 2018, 19:11
DeganEspero wrote:Wah topik bahasannya seru
kalo ga salah ada forum nya kan megasquirt ?
kalo mau set up ECU simple ya kayak ECU zaman baheula aja.....cuman atur fuel.....berdasar bacaan intake (vakum - MAP / AIT or MAF) dan TPS
ignition timing manual
lalu program utk penyesuaian thd elevasi berdasar bacaan MAP sensor
CMIIW
buscepat
Post by buscepat » 27 May 2018, 20:07
Nainggolan21 wrote:
nicky wrote:
Nainggolan21 wrote:
26 May 2018, 13:53
Mau tanya donk,
Masih perlu angka ya om? Image
Anps remapan sapa nih yg jadi korban cumi.. Image
ipOi78
Post by ipOi78 » 27 May 2018, 21:19
Mo nanya kl santafe crdi rpm bawahnya < 2000rpm bs dibikin enteng ? Apakah nanti kl diremap kompensasi ke rpm > 2000 jd berat ? Lama pengerjaaan brp lama ya ?
Post by Turboman » 27 May 2018, 22:26
ipOi78 wrote:Mo nanya kl santafe crdi rpm bawahnya < 2000rpm bs dibikin enteng ? Apakah nanti kl diremap kompensasi ke rpm > 2000 jd berat ? Lama pengerjaaan brp lama ya ?
exhaust ada Katalik gak ?
kalo ada babat dulu tuh Katalik, bikin plong
kalo EGR sih bisa ditutup dgn ReMap
Kalo odo udah tinggi, better lakukan servis pembersihan Vane Turbo......di Delta Tehnik bisa
setelah semua oke baru ReMap
Post Reply
