Permisi om, mobil saya toyota ipsum tahun 99. lampu indikator abs dan airbag di mobil saya nyala. Setelah saya jumper tc + e1 di soket diagnosis hasil kodenya seperti ini
Abs
13 = abs motor relay open circuit
21 = right front solenoid open or short circuit
22 = left front solenoid open or short circuit
23 = right rear solenoid open or short circuit
31 = right front speed sensor signal malfunction
32= left front speed sensor signal malfunction
33 = right rear speed sensor signal malfunction
34 = left right speed sensor signal malfunction
41 = excessively low or high battery voltage
49 = stoplight switch open or short circuit
Airbag
13 = short in circuit between D+ wire harness and D- wire harness.
Apakah ada kemungkinan bisa diperbaiki ? Kira-kira bengkel yg rekomen buat repair abs dan airbag dimana ya om ? Mohon infonya. Thankyou.
Regards
Abs & SRS airbag warning light
- Daily Vehicle: Toyota ipsum
