Foday Lanfort SUV = the next Es*mka SUV ?
As subject
Biar kalo suatu hari muncul dgn logo E ya gak pada heran deh
Foday Lanfort / Lanfu
Panjang 4771 mm
Weelbase 2790
Harga RMB 100 - 150.000
Ada yg 4X2 dan 4X4
Trans Manual
Mesin :
Mitsu SAME 2400 cc Petrol
Yunnei Kunming (FEV devp) 1900 cc CRD
Panjang 4771 mm
Weelbase 2790
Ada yg 4X2 dan 4X4
Trans Manual
Mesin :
Re: Foday Lanfort SUV = the next Es*mka SUV ?
Ya nih,
kemarin ada yang share foto d cab esemka plat profit AD, tapi profil lampu belakang kayak foday f 22..
Esemka yang kemaren viral, fix rebadge kan??? Jadi esemka kerjasama sama foday apa gimana.
Yg terjadi Malaysia
It appears that a new national carmaker will be formed soon. Azizul Hj Tandek, managing director of Enggang Keramat Automobile, toldpaultan.org that the company will be launching a new Malaysian car brand called SAF – named after the arrangement of Muslims in prayer – in April this year.
The new lineup will consist of rebadged versions of models from the Chinese brand Foday, namely the Lion F22 pick-up truck and the Landfort seven-seater SUV. The two vehicles will be badged as the SAF Striker and SAF Landfort respectively, and will look identical to the Foday models, albeit with SAF badging. Both models will be built at Oriental Assemblers in Tampoi, Johor,
https://paultan.org/2016/02/29/new-mala ... ay-models/
Thema-nya juga = MobNas / Local Brand
wkwkwkkwkwkkwkwkq
wkwkwkkwkwkkwkwkq
Semoga mobnas bukan sekedar mimpi lagi
- Daily Vehicle: Innova
Yep, Esemka kerjasama sama Foday sejak 2010...
Rebadge menurut saya merupakan awal yang bagus. Kaya Proton kan gitu, awalnya nyeplak punya Jepun dan akhirnya bisa bikin mobil hasil riset sendiri
Jangan nginjek gas dalam dalam, boros, mending nyantai aja
Sebelum bermimpi kelewat jauh
saya ingin tahu
Persh & pabrik MobNas Esemka di sini komposisi kepemilikan sahamnya brp : brp persen ?
siapa investor lokalnya ?
Lalu goal investor lokal-nya ini apakah nantinya ingin membuat mobil sendiri ataukah akan terus tergantung dari partner asingnya ?
Mending cari tahu dulu deh........
he he he.....
saya ingin tahu
he he he.....
Yang oe takutin cuma pasang emblem euy. Kayak cerita timor dulu, yang dibilang mobnas, tapi turun kapal udah bisa dikendarain
Tertawalah sebelum tertawa itu dilarang
- Daily Vehicle: 4 Banger
Paling enggak di redesign dikit gitu, masa ini sama plek cuma ganti logo doang
NCP91R
TGN140R
NCP91R
TGN140R
yg lucu sampe skg di arena diskusi manapun, kalo ada yg posting gbr mobil Esemday lgs muncul komen2 berapi api........
padahal kita gak pernah tahu apa tu mobil beneran dirakit di sini atau datang utuh dgn label baru .......wkwkwkwk
And the next problem, jika harga yg di tawarkan setara dengan merek-merek mobil yang sudah mapan atau sedikit di bawah merek-merek mapan ? Apakah masyarakat umum bisa menerima dengan luas dalam artian membelinya.
Problem nya, banyak orang yg mendukung program mobnas tp ketika di sodori barangnya malah pikir-pikir dulu.
Suruh orang lain beli, tapi yg nyuruh malah masih mikir2.
Kalau andalkan permintaan dari pemerintah, nanti kalau muncul kendaraan mobnas lainnya bagaimana ? Apakah akan di bagi2 kuenya.
Untuk kendaraan Nasional saya lebih prefer ke GESITS, secara desain pengembangan di lakukan oleh Swasta dan Perguruan Tinggi dlm negeri.
Target produksi jelas.
Dan Roadmap pengembangan nya pun lebih jelas.
Maybe, jika motor GESITS sukses, sangat mungkin mereka akan lakukan pengembangan untuk Produksi kendaraan Roda 4.
yang episode kemarin
https://m.detik.com/oto/mobil/1851476/e ... -6000-unit
wow juga kalau beneran iya
dan katanya produksinya keroyokan beberapa smk sama home industri hehehehe
daydreaming lagi
Ini mobil yg 'dipakai' 5 tahun sekali jadi nggak perlu jelas investor atau detail teknis spt apa. Yg penting bisa 'jalan' dulu. Selanjutnya... gak penting ...heheheTurboman wrote: ↑Mon Sep 25, 2017 11:12 Sebelum bermimpi kelewat jauh
saya ingin tahu
he he he.....
lbh aman beli wuling drpd ini krn ud niat bikin pabrik gede di deltamas
- Daily Vehicle: CM5
g4ndalf wrote: ↑Tue Sep 26, 2017 2:22Ini mobil yg 'dipakai' 5 tahun sekali jadi nggak perlu jelas investor atau detail teknis spt apa. Yg penting bisa 'jalan' dulu. Selanjutnya... gak penting ...heheheTurboman wrote: ↑Mon Sep 25, 2017 11:12 Sebelum bermimpi kelewat jauh
saya ingin tahu
he he he.....
betull yang penting bisa dijadiin bahan pencitraan buat pemilu 2019...sisanya tak pentingg
Past : G100 CB-23 '87, DanGan 4G15 '90, Fj 40 '82, TBR541 LS At '00, T32 QR25DE '16, C24 QR20DE '11, F30 330i, GK 5 MT '15, C11 MR18DE '06
Present : CM5 K24 '04, RV3 '22
- Daily Vehicle: Pajero 4N15
Gak perlu susah2 bikin pabrik..
Prinsipal, ATPM atau "Sohibul Hajat" kan cukup modal cutting sticker 20 ribuan,
Kan cuman 5 tahun sekali, re-emblem.. dan jadilah Esemka !
- Daily Vehicle: nmax
No offence ya, dari dulu awal2 keluar 2012 yg pake lampus crv RE, saya udh enga yakin bisa 'seenggaknya' di produksi minimal 100 unit aja
Semoga kedepannya bisa punya mobnas, lebih bagus lagi kalo bisa punya EV
kyknya logo esemka hrs ganti jgn kyk dulu. hrs diubah jd oval biar gampang rebranding ke merk lain... tinggal tempel plekk.........
kita ini memang jagonya jahit, tapi gak papa lah. wong pemerintahnya juga gak pernah serius kepengen punya mobnas, atau disandera apm yang udah berakar kuat disini? saya jadi inget cerita oom soeparto soejatmo dulu waktu mengembangkan mobil kecil untuk cikal bakal mobnas, dihalang2i oleh orang yang katanya "suruhan jepun" untuk gak meneruskan proyek tsb. karena ngeyel gak mau, walhasil mereka ngalah dan minta part2nya disupply perusahaan senegera mereka i.e carbs, plugs, etc. kemudian proyek tsb nguap krn krismon 97/98..
Oe suka penasaran dengan pabrikan seperti ini.
Terutama di divisi R&Dnya.
Penasaran aja dengan target, cara kerja, & kualitas pekerjaannya.
SUBARU INDONESIA
Instagram : subaru.sales.id
Sebenernya ini kesempatan foday, mumpung brand ambasadornya masih ngejabat, ya biarin dibeli sama fans2nya yg kemaren
Sampingnya mirip highlander tapi dengan steroid yg overdose dan kap mesin juga tinggi bener kaya liat prado sama everest jadinya
Anyway esemka didenger sebagai merk kaya main2, kurang cocok apalagi logonya, coba smk masih sebutan stm, bikin mobil merk esteem, keren tuh
Sheer driving pleasure next time
