Moderators: Ryan Steele , sh00t , r12qiSonH4ji , avantgardebronze , akbarfit
yanuarra
Posts: 3985 Joined: Sat Dec 28, 2019 9:55
Post
by yanuarra » Sat May 04, 2024 4:18
Profith83 wrote: ↑ Fri May 03, 2024 4:25
Deep Socket 21 19 17 14 12
Yang 10 kebawah punya set pakai drive 1/4
KTC kinclong, KTC keren
yanuarra
Post
by yanuarra » Sat May 04, 2024 4:20
mkamil wrote: ↑ Fri May 03, 2024 1:41
Produk yang biasa-biasa saja dan murmer, jgn di bully
Keren omm
Posts: 26986 Joined: Sat Jan 31, 2009 17:48
Post
by DOHC » Sat May 04, 2024 4:41
yanuarra wrote: ↑ Sat May 04, 2024 4:18
DOHC wrote: ↑ Sat Apr 27, 2024 23:13
btw
penasaran ama mbah tugel punya wera digital
masi awet ga yah lcd nya ?
Hadiiir
Masi normal kok
lcd yurop lebi bagus dari nippon brarti
yanuarra
Post
by yanuarra » Sat May 04, 2024 4:45
DOHC wrote: ↑ Sat May 04, 2024 4:41
btw
Hadiiir
Masi normal kok
Kuncinya baterai kudu dilepas mbah (kalo mau disimpen agak lama)
Agak repot memang
yanuarra
Post
by yanuarra » Sat May 04, 2024 4:46
Nubie belajar ganti bf dlu
Post
by DOHC » Sat May 04, 2024 4:51
yanuarra wrote: ↑ Sat May 04, 2024 4:45
Hadiiir
Masi normal kok
Agak repot memang
ud dilepas mbah
tp rusak nya tu bukan kaya kena batere bocor, tp LCD nya bocor item item gt
beda kl kena batere bocor
Post
by DOHC » Sat May 04, 2024 4:52
yanuarra wrote: ↑ Sat May 04, 2024 4:46
coba foto dan crita nya lebi banyak dan lebi jelas biar kita2 orang disini pd ngarti
ntar kl ga
ngana bakal kena semprot ama mbah nganu yg nyentrik itu
dibilang kaya yg onoh doyan poto2 geje
Profith83
Posts: 4616 Joined: Mon Jul 14, 2008 2:54
Post
by Profith83 » Sat May 04, 2024 5:53
Omnibus wrote: ↑ Fri May 03, 2024 7:49
wih rame ...
Mode irit mbah beli ketengan.
21 19 17 deep socket pakai drive 1/2
14 12 pakai drive 3/8.
10mm ada di bahco set
Kuat kan ratchet 1/4 bahco untuk deep spcket bahco 10mm?
Profith83
Post
by Profith83 » Sat May 04, 2024 5:56
Siap siap mbah ... belum pasti terpakai.
Yang selalu terpakai 21mm deep socket nya
Posts: 11403 Joined: Tue Apr 08, 2008 10:12
Post
by Omnibus » Sat May 04, 2024 8:19
Profith83 wrote: ↑ Sat May 04, 2024 5:53
wih rame ...
kuat. yg ga kuat tangan kita nya.
ada cerita kemaren ini sy ngelepas egr valve jazz (mesin sm dgn hrv) utk cleaning. bautnya kan 12mm. dan posisinya nyerong. jd hrs pakai extension wobble. extension biasa pasti mentok ke kepala egr valve nya. nah itu kerasnya minta ampun crack open bautnya krn heat cycle kali. kl main hajar pasti patah di dalam tuh baut.
jd hrs pakai trik jitu.
Profith83
Post
by Profith83 » Sat May 04, 2024 8:24
Omnibus wrote: ↑ Sat May 04, 2024 8:19
wih rame ...
12 mm pakai drive berapa mbah?
Post
by Omnibus » Sat May 04, 2024 8:54
Profith83 wrote: ↑ Sat May 04, 2024 8:24
3/8
singachu
Posts: 1290 Joined: Mon Jan 07, 2008 3:10
Post
by singachu » Sat May 04, 2024 10:35
Omnibus wrote: ↑ Sat May 04, 2024 8:19 main hajar pasti patah di dalam tuh baut.
bagi dong
itu wooble ext Stalhwille ama KTC kan beda shape.
Kerasa pas pakai muternya bedanya gmn ?
max sudutnya beda ga ?
regards,
singachu
Peter10
Posts: 58 Joined: Sat Apr 07, 2018 3:06
Daily Vehicle: L15Z
Post
by Peter10 » Sat May 04, 2024 11:45
Mbah suhu,
Minta saran tang potong yg mendingan utk potong kabel listrik.
Pake merk tek... gampang tumpul sama gompal sisi tajamnya.
Makasih sebelumnya.
Posts: 11117 Joined: Wed Oct 16, 2013 6:27
Post
by marmut » Sat May 04, 2024 12:07
Peter10 wrote: ↑ Sat May 04, 2024 11:45
Mbah suhu,
Makasih sebelumnya.
knipex.
sekali beli untuk seumur hidup kalo nggak ada yg ngembat.
Post
by marmut » Sat May 04, 2024 12:08
Omnibus wrote: ↑ Sat May 04, 2024 8:54
3/8
boleh dibantu mbah, saya butuh mata sok 10mm sama 12mm yg sq. dr. 1" beli dimana ya?
Post
by Omnibus » Sat May 04, 2024 12:10
marmut wrote: ↑ Sat May 04, 2024 12:07
Mbah suhu,
Makasih sebelumnya.
knipex.
baru mau ngomong yg persis. keduluan.
Post
by Omnibus » Sat May 04, 2024 12:11
marmut wrote: ↑ Sat May 04, 2024 12:08
3/8
di indihe sono .... mrk pake engkol L 1" utk apapun sekalian ngebarbel katanya
Post
by Omnibus » Sat May 04, 2024 12:15
singachu wrote: ↑ Sat May 04, 2024 10:35
bagi dong
kepala baut dipukul pakai drift punch lapis majun + palu. buat ngelepas ulir lengketnya. pukulnya pelan pake kasih sayang + sepik2 beracun.
pake semprot penetrant juga sih (bukan wd40, yg lbh strong merk bebas).
Post
by marmut » Sat May 04, 2024 13:03
Omnibus wrote: ↑ Sat May 04, 2024 12:15
bagi dong
mbah
singachu
ybs itu mau bilang kepala bautnya dipukul pake palu tembaga harga 1 juta tp nahan diri, takut dibilang pamer.
Post
by Omnibus » Sat May 04, 2024 13:31
marmut wrote: ↑ Sat May 04, 2024 13:03
bagi dong
mbah
singachu
engga mbaaahh
palunya punya tp drift punch nya msh yg bekas long terot.
yg ini brass punch msh ngendon di wishlist udah taunan. bareng wislis2 laennya
salahkan becuk!
nasip hidup di ujung dunia
Profith83
Post
by Profith83 » Sat May 04, 2024 22:59
bagi dong
regards,
singachu
Kayanya mirip2.
3/8 belum pernah pakai. Yang 0.5 pernah pakai, jadi gak bisa bedain
Profith83
Post
by Profith83 » Sat May 04, 2024 23:02
3/8
Wih ngeri juga yah kalau asal paksa.
Pernah juga bengkel buka baut EGR innova reborn diesel.
Yang satu kebuka gak ada masalah, biarpun susah.
Nah satunya lagi hampir selek kepalanya
Post
by DOHC » Sun May 05, 2024 0:05
Mbah suhu,
Pake merk
Makasih sebelumnya.
TEKIRO kan, biasa itu
barang ampas buang2 wang aj
sesuai ikut saran mbah2 dsini aj, knipex, bsa beli di glodok atau ltc
atau kl kaki kuat mulut kuat, bsa iseng muter2 glodok yg pasar jaya sana, minta yg merek tjap trompet, buatan negeri gmbh
ini mbah nya knipex nehh , tukang2 listrik jaman eyang harto dulu biasa borongnya tang potong ini di glodok
chucky
Posts: 5 Joined: Thu Sep 20, 2018 10:43
Post
by chucky » Sun May 05, 2024 10:11
DOHC wrote: ↑ Sun May 05, 2024 0:05
corneta bukan mbah?
