HRV e:HEV tanda HPM strikes back?
Forum rules
Re: HRV e:HEV tanda HPM strikes back?
sengaja turbo RS dinaikin 550jt biar hev RS keliatan turun banyak
padahal dulu jg launchingnya harga 499 tuh turbo RS
- Daily Vehicle: 2013 GE8 TYPE S + GONTA GANTI KAYA KOKAY
bener juga gak laku ini terus stock nyangkut tinggal kasih disc 50jtdarrelund wrote: Tue Jun 10, 2025 8:59 sengaja turbo RS dinaikin 550jt biar hev RS keliatan turun banyak
- Daily Vehicle: L15ZF MT+1KRVET MT
yah mbah masa CUV ma 7 seater dikasih lampu brio.Suryaputra wrote: Tue Jun 10, 2025 8:46Owh i ckayukayuthe5th wrote: Tue Jun 10, 2025 8:32yang lowest grade masi halogen mbah.Suryaputra wrote: Tue Jun 10, 2025 8:20
Projie?
Kan dah led?
Projie itu ngurangin intensitas cahaya, tp cahaya lbh fokus emang.
Jd watt hrs lbh tinggi.
kalo LED buat RS atleast trim e kasih lah halogen projie macem HRV RU![]()
Nunggu FL lagikayukayuthe5th wrote: Tue Jun 10, 2025 11:39yah mbah masa CUV ma 7 seater dikasih lampu brio.Suryaputra wrote: Tue Jun 10, 2025 8:46Owh i ckayukayuthe5th wrote: Tue Jun 10, 2025 8:32
Harga mirip
city ma hatchback ga ngotak harganya wkwkwk *dahlah honda kalo ganiat jualan mending kaia si toyota hapus aja tuh yaris heheSuryaputra wrote: Tue Jun 10, 2025 11:41Nunggu FL lagi
Harga mirip
kan udah pake PF2 abis ini kan peres ampe sepet tuh PF1 haha FL , harga mirip
Coba nih yaSuryaputra wrote: Tue Jun 10, 2025 7:19Yah gmn yaaaMSU wrote: Tue Jun 10, 2025 6:50 yang punya hrv generasi sebelumnya apa ga nangis ini ya...
harga baru-nya jadi mirip generasi sebelumnya tapi bekas?
Namanya juga gak bs please everyone.
Drpd makin bnyk diler tutup lg
Better late than.......![]()
Yg jaman dulu bungkus HRV turbo (500jt) pas tahun 2022.
Tahan keinginan trus, convert duitnya jadi emas batangan
Jual emasnya di taon 2025.. udah cuan berkali-kali lipat
Trus beliin HR-V RS hybrid seharga 488 jt
Hitungannya gini :
Tahun 2022
Emas 1gr = IDR 988k . Tarolah 1 jeti / gram
500 jt (Dana beli hrv turbo RS) = dapet 500 gram (1/2 kilo)
Tahun 2025
Emas 1gr = IDR 1.9 jeti
Jual (1/2 kilo) 500 gram = dapet duit IDR 950 juta
Beli HRV hybrid RS
950 jeti - 488 jeti
= masih sisa 462 jeti masuk kantong
Emang yah tahan keinginan hawa nafsu buat belanja (hal yg penting ga penting) banyak manfaatnya
Sheer Repairing Pleasure
seru banget nih liat harga hrv ehev nya.
buat yacros dan kretah, pilihannya tinggal gedein gudang buat nyetok ato gedein diskon wkwkkw
utk yg pegang hrv seri non hybrid sih...... nangis dah ini harga 2ndnya. padahal hrv 2nd gen terkenal banget harga bekasnya nahan banget. skrg yg gen3 ini setelah nongol harga ehev gini sih ambyarrr.......
thank u mobcin
thank u mobcin
jangan pesimis dulu napeeeee, posthink mbah posthinkb0ku wrote: Tue Jun 10, 2025 9:06
bener juga gak laku ini terus stock nyangkut tinggal kasih disc 50jt![]()
ini beda behavior konsumen mbah
klo kelasan crv mah ngeluarin duwit buat 98 cuek bebek aja, hrv malah kebalikannya
possible aja laku sih, atau atleast ga ngenes kyk kmrn
kira" HRV peslip ini ada imp kaki"kyk kemarin ga yak
Iya jual beli gold nya di app pluangKielConstantine wrote: Tue Jun 10, 2025 14:26Coba nih yaSuryaputra wrote: Tue Jun 10, 2025 7:19Yah gmn yaaaMSU wrote: Tue Jun 10, 2025 6:50 yang punya hrv generasi sebelumnya apa ga nangis ini ya...
Hitungannya gini :
Tahun 2022
Tahun 2025
Beli HRV hybrid RS
950 jeti - 488 jeti
= masih sisa 462 jeti masuk kantong![]()
Effortless
Yarcross HEV bener nangis di pojokan.
Iritnya mirip, tp BQ jauh better, lbh kentjang, dan handling ya honda yg dah mature lah.
Makin happy ini mahmud sosialita
tapppiiiiii bangggg. tahun depan dah muncul EHEV 2.0Suryaputra wrote: Tue Jun 10, 2025 15:39Iya jual beli gold nya di app pluangKielConstantine wrote: Tue Jun 10, 2025 14:26Coba nih yaSuryaputra wrote: Tue Jun 10, 2025 7:19
Yah gmn yaaa
Hitungannya gini :
Tahun 2022
Tahun 2025
Beli HRV hybrid RS
950 jeti - 488 jeti
Emang yah tahan keinginan hawa nafsu buat belanja (hal yg penting ga penting) banyak manfaatnya![]()
Effortless
setidaknya masalah CVT "ringkih" dah gada. and beware ini EHEV 1.0 masih belum bisa battery assist di high speed. jadi makanya si honda ga kasih figur kombinasi power karena ini kan 1.5 masih turunan dari IMA cman ganti di transmisi doang. (hybrid mode isi motor pake bensin, high speed murni engine only)Suryaputra wrote: Tue Jun 10, 2025 16:14 .
Makin happy ini mahmud sosialita![]()
jadi ini masih gwa katakan series-engine drive belum series-parallel
Wow.. harganya memang cakep.
Berarti, tinggal nunggu diskon besar tuk Yaris Cross HEV kayak 50 jutaan gt atau Creta turbo diskon 50 jutaan.. wkwkwkwk..
Ada satu yg kepikiran sama HRV HEV ini, posisi batere kan di bagasi yang rada ke depan yaa.. berarti ACnya harus setelah dingin banget tuk bawa pendinginannya ke belakang yaa..
Kalau ga salah Yaris Cross sama kayak Corolla Cross Hybrid tuk di bawah bangku penumpang belakang, zenix di bangku penumpang depan. Jadi mesti bersih bener neh baik bagasi maupun penumpang belakangnya di mobil2 ini yaa..
dukun mobil 5-10thn lagi ganti konten bukan CVT ambrol tapi BATRE hybrid ambrol...........Suryaputra wrote: Tue Jun 10, 2025 16:14 IMG_20250610_231559_176.jpg
Selama peredaman kolong roda dan bagian bagasi masih selembar kertas A4 nga akan saya balik ke Honda (HRV).
mirip2 koq eksekusi di lapangan.kayukayuthe5th wrote: Tue Jun 10, 2025 23:56tapppiiiiii bangggg. tahun depan dah muncul EHEV 2.0Suryaputra wrote: Tue Jun 10, 2025 15:39Iya jual beli gold nya di app pluangKielConstantine wrote: Tue Jun 10, 2025 14:26
Coba nih ya
Hitungannya gini :
Tahun 2022
Tahun 2025
Beli HRV hybrid RS
950 jeti - 488 jeti
Effortless
setidaknya masalah CVT "ringkih" dah gada. and beware ini EHEV 1.0 masih belum bisa battery assist di high speed. jadi makanya si honda ga kasih figur kombinasi power karena ini kan 1.5 masih turunan dari IMA cman ganti di transmisi doang. (hybrid mode isi motor pake bensin, high speed murni engine only)Suryaputra wrote: Tue Jun 10, 2025 16:14 IMG_20250610_231559_176.jpg
klo dah di tol, intinya sama2 pakai bensin, krn buat ngecharge jg ambil sebagian arus listrik dr generator.
klo honda ini sy blm TD. menarik juga wkwkwkw
udah ada, tp merknya toyota wkwkwkwb0ku wrote: Wed Jun 11, 2025 0:40dukun mobil 5-10thn lagi ganti konten bukan CVT ambrol tapi BATRE hybrid ambrol...........Suryaputra wrote: Tue Jun 10, 2025 16:14 IMG_20250610_231559_176.jpg
ganti per bagian batt-pack yg dah ambrol dan voltasenya beda sendiri lbh rendah
klo honda jualan bnyk, ya makin bnyk kontennya,
jadi pada takut pk hybrid, dan EV, terus balik lg (plot twist) ke ICE
Ini berarti eHEV 1.5L di all new hrv ini baru ya?
Combined 106ps/127nm dengan 131ps/250an nm kira2 dapet berapa ya?
Bener2 beda sama honda IMA lawas di fit/crz khan ya?
Soalnya eHEV honda selama ini yg ada ya 2.0 combined 204ps di civic/crv/accord
Jadi penasaran juga sama figur akselerasi dan top speednya
Present
Past
G15B 5MT 00
K20A 5MT 03
J20A 5MT 08
Past
G15B 5MT 00
K20A 5MT 03
J20A 5MT 08
klo test dr reviewer luarariswp wrote: Wed Jun 11, 2025 3:07 Ini berarti eHEV 1.5L di all new hrv ini baru ya?
aksel 0-100 kph = 9 detik kecil
top speed 170-180 kph (ada posting YT test nya di autoban jeman)
- Daily Vehicle: honda
kalo e:hev kayaknya ga ada combined power omariswp wrote: Wed Jun 11, 2025 3:07 Ini berarti eHEV 1.5L di all new hrv ini baru ya?
karena motor listrik dan ICE ga akan pernah gerak bersama menggerakkan roda
ketika slow speed, motor gerakin roda.. kalo batere uda mau abis, ice cm idup buat isi batere
ketika high speed, ice gerakin roda. motor ga assist.
sebagaimana ane liat di https://global.honda/en/tech/two_motor_ ... onda_eHEV/
yg bingung, kenapa ada combined power di tech specs crv indo
dan diagramnya beda dengan link yg di atas
kemungkinan sih, emang beda2 ehev yg ada....
kalo liat2 tes aksel hrv ehev ini, emang dr awal gas betot, lgsg idup itu ice
jelek jelekin tapi kalo ada duitnya mau.b0ku wrote: Wed Jun 11, 2025 0:40 dukun mobil 5-10thn lagi ganti konten bukan CVT ambrol tapi BATRE hybrid ambrol...........![]()
itulah dukun mobil.
tau tuh aneh
koq ada hobi fearmongering & jualan bengkel rusaknya
"cvt jelek, benerin di saya aja"
pan lalu ngmongin cvt almaz jelek, tau ndiri fans keras mocin gimana, dibanting lah dia
beneran om selembar kertas A4? Sudah A4, terus yg 70gram utk fotocopy lagi jgn2.peterming77 wrote: Wed Jun 11, 2025 2:17 Selama peredaman kolong roda dan bagian bagasi masih selembar kertas A4 nga akan saya balik ke Honda (HRV).
Ada foto contohnya gak om? lumayan referensi biar dipertebal dan perluas di mobil sendiri.
itu kan sama kayak bilang honda kaki kakinya ringkih, tapi dia sendiri buka bengkel kaki kaki.darrelund wrote: Wed Jun 11, 2025 4:20
tau tuh aneh
pan lalu ngmongin cvt almaz jelek, tau ndiri fans keras mocin gimana, dibanting lah dia![]()
belakangan sering banget seliweran si dukun shortsnya ngobrol sama si denk*s, yang jadi target dia mobil high maintenance dibilang a b c d e, ya ente ngomong gitu, wong punya bengkel. mana si denk*s cuma manggut manggut doang.
- Daily Vehicle: Voxy
Dukun ini kemarin sempet saya liat sekilas bahas cvt toyota tapi saya lupa mobilnya apa. Mungkin raize km masih rendah. Trus kayanya banyak fans keras toyota yg ga terima.
Cuma saya cek lagi kok ga ada ya post nya
betul raize....kl ga salah odo 50rb-an kmtimbermaniac123 wrote: Wed Jun 11, 2025 5:10 Dukun ini kemarin sempet saya liat sekilas bahas cvt toyota tapi saya lupa mobilnya apa. Mungkin raize km masih rendah. Trus kayanya banyak fans keras toyota yg ga terima.
cm video penjelasan kenapa cvt-nya error kayaknya blm muncul
