Ranking Dan Pemilihan Oli Mesin - PART 02
Re: Ranking Dan Pemilihan Oli Mesin - Part 02
cobain castrol GTX 10w40 Diesel VS Meditran SC wah kualitas hampir 50 % bedanya
mau tanya nih...oli mobil1 5w-50 tahan brp km ya?....uda cari2 di google tapi lum dapat jawaban...
kalau nurut pabrikan sih 5000 km tapi pabrikan mobil menganjurkan masih sanggup sampe 10 000 kmr1kr1k89 wrote:mau tanya nih...oli mobil1 5w-50 tahan brp km ya?....uda cari2 di google tapi lum dapat jawaban...
ini salah satu petunjuk dari Castrol
What sorts of intervals are recommended for changing engine oil ?
The standard criteria for changing engine oil are distance and time. Generally, 3-5,000km or 6 months (whichever is first) is the interval normally used in Japan. Although the actual trend for oil change intervals as specified by the manufacturers is trending towards 10-15,000km plus (or once a year), to really keep an engine consistently working in prime condition people often replace their oil at shorter intervals. Furthermore, for vehicles that have higher power output, turbo cars and diesel cars, or those on severe drive cycles, short change cycles are recommended depending upon conditions of use.
It may seem strange, but using your car for short trips only (such as a quick 10 minute or so visit to the local supermarket) means that the engine oil does not heat sufficiently and water and fuel can accumulate in the engine, leading to a build-up of sludge and rust, and causing wear. So, in actual fact, the belief that the car has not covered much distance and therefore changing the oil isn't necessary is misled. The true condition of the engine oil in a car is difficult to assess and careful regular maintenance is important to maintain peak performance.
ohhh..gitu ya...
klo oli toho tau ga?...
itu bisa tahan mpe 100rb km...kira2 bner ga tu?..
Wakssss 100rb km ???r1kr1k89 wrote:ohhh..gitu ya...
Ngalah2in oli yg ane sebut om bisa ampe 80rb km
Om TM pasti pernah denger brand Omega yang katanya longlife banget juga intervalnya?
ya omega emank tahan juga katanya...tapi kurang tau juga de..
Omega mrk sebenarnya penyuplai aditif bukan pembuat oli,kuncinya buka di base oil tp di aditifnyar1kr1k89 wrote:ya omega emank tahan juga katanya...tapi kurang tau juga de..
Omega harganya ngeri om. Hitungannya buat additive oli dlm mililiter.Per mili kl gak salah diatas 100rb. CMIIW.
Live as if you'll die today
oli mahal gak guna kalau udah ketemu yg namanya banjir ataupun macet nah loe , mending pake yg standar saja jadi kalau rusak enak gantinya
Barusan liat....pennzoil platinum bakalan ada nih...mantap...
Ada yg pernah test lab sample oli bekas ?
Jika ada yuk kita saling tuker data, ane ada bbrp hasil uji lab dari bbrp merek oli yg berbeda, utk range jarak antara 8500 Km s/d 21.000 Km
Di bawah ini salah 1 contoh hasil UOA (Used Oil Analysis) dari sebuah oli 5W30 Full Synth yg jalan 10.000 Km dlm 10 bulan di Honda CR-V gen. 3
Maaf oom...OL dr mobile site..gak gitu keliatan....kalau diketik saja hasil nya baru keliatan Pak TM:)
Tengkiu...dan sorry uda ngerepotin
Apa yah merk oli om turbo ? Dr bb jg ga bisa liet neh hiks
Bole tebak2 ga yg 5w-30 itu ? Total quartz 9000 future ? Caltex energy ? Motul h tech plus ? Apalagi yah pada lupa merk2 full syn 5w 30 hihi
saya cari2 castrol gtx diesel yg 10w40 kok ga ada ya? udah keluar masuk banyak toko di surabaya...adanya yg 15w40solar_kerosen wrote:cobain castrol GTX 10w40 Diesel VS Meditran SC wah kualitas hampir 50 % bedanya
Om turbo kemana neh
Ane punya bbrp hasil UOA dari oli berbagai merek dengan beragam jarak tempuh, semuanya 8500 Km ke atas.fernando_lim wrote:Apa yah merk oli om turbo ? Dr bb jg ga bisa liet neh hiks
Itu sheet yg ane tampilkan sebetulnya hanya utk contoh aja, kalo test UOA itu parameter apa aja yg di test.
Turboman wrote:Ane punya bbrp hasil UOA dari oli berbagai merek dengan beragam jarak tempuh, semuanya 8500 Km ke atas.fernando_lim wrote:Apa yah merk oli om turbo ? Dr bb jg ga bisa liet neh hiks
coba dikeluarkan datanya semua bro secara kita sama sama pemilik kendaraan diesel
Ada yg pernah bandingin mobil s 10w-40 vs petronas syntium 800 10w-40 vs total quaetz 7000 10w-40 ? Dari segi performa dan daya tahannya
Baru aja ketemu temen lama sekarang kerja di idemitsu ane mintain katalognya baru tau ane idemitsu ada fully syn jg rupanya,ada 2 sae 5w 40 dan 5w 30 harganya masing2 102.000/liter dan 96.000/liter keduanya sudah api sm juga
Ada yg pernah jajal idemitsu fully syn ? Soalnya dibeberapa forum cuma ada review mineral dan semi syn doank
Bingung bingung.co.id neh jajal petro canada apa idemitsu full syn yah soalnya 2000km lagi jadwal ganti oli jd cari info spek n harga oli dulu neh
om Turboman tanya:
antara Shell Helix Diesel HX7 dgn FK Pulse GT recomend mana ya? Untuk innova diesel bro.
Pak imsus2c, toko oli yg di Kedungdoro itu namanya UD. Sinar Jaya bukan? Jl. Kedungdoro 125?
Vorsprung durch Technik
The Pursuit of Perfection
From Zero to Hero
Air Tenang Menghanyutkan
Ilmu Padi
From Zero to Hero
Ilmu Padi
Sy belom pernah UOA keduanya, tapi dr pengalaman coba antar sesama 10W-40 semi synth khusus Diesel umumnya result 11-12 lah.juanaxel wrote:om Turboman tanya:
waduh...apa ya namanya...lupa, maafsmgandi wrote:Pak imsus2c, toko oli yg di Kedungdoro itu namanya UD. Sinar Jaya bukan? Jl. Kedungdoro 125?
itu masih berdekatan dgn deretan toko2 variasi yg suka pasang/jual aksesoris, dan kalo ga salah masih 1 blok dgn indo (atau alfa) mart ya...
apa sudah ada yg coba oli shell yg co-branding astra?
