Honda CBR 150 R VS Yamaha V-Ixion!!!
CBR wins all....
Terutama menang harganya oom xixixixih3ndryg wrote:di Motorplus yg baru ada tuch komparasi antara CBR150, Vixion, dan Pulsar.
Untuk keseluruhan yg menang CBR
Btw, kok di situ dibilang power CBR gak sampai 15 HP yah?
Re: CBR wins all....
Hah? CBR ga sampe 15 HP? di brosurnya 21 HP koq.>>????drajattop wrote:Terutama menang harganya oom xixixixih3ndryg wrote:di Motorplus yg baru ada tuch komparasi antara CBR150, Vixion, dan Pulsar.
1+1 = ?
Ane rada sedikit gak percaya apa yg dikatakan brosur disini (sorry yah no offense buat pengguna CBR).NYoman wrote:makanya, kabar dari mana lagi tuh...
CBR kan 21Hp
Beberapa forum luar, juga sering ngebahas masalah ini, apalagi kalo coba ngecek di website2 yg jualan CBR ini, selalu gak ada yg mencantumkan besaran HP ato torsi-nya.
Kalo gak percaya coba aja browsing........
Kalo yg ane dapet (berdasarkan baca forum2 luar) mereka bilang power CBR antara 16-17 HP, tapii aslinya ane gak tau.......
Gimana mau tau, ane punya aja nggak......
Peace ahh.......
@om novasonic
kalo ga salah dulu pernah ada anak cbr club yg nyobain bener apa ga 21 HP itu di dynometer..
n katanya sih bener...
tapi ga tau jg ya....gw jg lom pernah nyobain pake dynometer...di bandung ga ada sih...hehehehhe....
kalo ada...gw rela nyobain deh...^^
C'mon, give me your hand!
So we can reach the horizon
@om novasonic
Tapi kalo menurut web ini:
http://indian2wheels.blogspot.com/2007/ ... an-we.html
powernya cuma 17 HP tuhh........ (jadi binun ane.....)
Techincal Specifications of the Honda CBR150R
* Engine 4 Stroke, DOC 4 Valves, Water Cooled
* Max Power: 17 bhp
* Cylinder Capacity 149.4 CC.
* Bore x Stroke 63.5 x 47.2 MM.
* Compression Ratio 11 : 1
* Engine Start Type Electric Start
* Ignition CDI Direct
* Transmission 6 Speeds
* Clutch Type Wet, Multiple Disk
* Dimension (W x L x H) 652 x 1,910 x 1,065 MM.
* Wheel Base 1,286 MM.
* Ground Clearance 172 MM.
* Seat Height 776 MM.
* Dry Weight 115 Kgs.
* Suspension Front: Telescopic
* Suspension Rear: Monoshock
* Brake Type Front Disc Brake, Disc Plate Size 276 MM.
* Rear Disc Brake, Disc Plate Size 220 MM.
* Tyre Size Front 80 / 90 - 17 M/C 44P (Tubeless)
* Rear 100 / 80 - 17 M/C 52P (Tubeless)
* Fuel Tank Capacity 10 Litrs
* Fuel Type Unlead Gasoline Octain 91 Up
Gw juga binun sich..tapi ambnil logika aja...21 HP itu bener..tp mungkin diukur di mesin, sementara 17 HP itu mungkin diukur di Roda...lah kalau hasil di Motorplus yg 14 sekian HP itu...perlu diklarifikasi lagi, pakai bensin apa, kondisi motornya walaupun baru banyak parameter yg perlu diliat..apakah setting karbunya sudah Fix..menurut gw data yg paling akurat justru punya V-xion krn dia sdh injeksi..which is yang ga perlu setting2x lagee
@novasonic
motornya di kasih premium apa primax..
pengaruh lho kayak gitu..
klo ga lebih dari 17ps berarti ga lebih jauh dari fu yang cuma 16.6ps(satria ane yang dulu.. berani bilang gini krn ud pernah dyno test..)
btw CBR 600 brp ya tenaganya??
kok di buku panduan ane ga ada ya, speknya..
biasanya kan ada..
biasanya kan ada..
Maksudnya pic motor CBR 150-nya bro nyoman ato CBR 600-nya dehh.........NYoman wrote:pict cbr 150?
minta ama bro gehu ato gauss..
ane ga punya..
CBR600RR yang itu klo ane pake njinjit..
ud gitu bodi guede...
buat boncenger kayaknya ga mungkin..
masalahnya nih motor design RCV212V..
tau kan motornya seberapa...
Kalo punya bro gehu ma gauss ane mah udah tau......
hehehhehehe......
begini riwayatnya...
pertama pake spd motor:
kelas 4-5 SD Suzuki Crystal (masih ada)
kelas 6sd-2smp honda supra xx (masih ada)
kelas 3smp suzuki satria fu 150 (ud dijual habis kecelakaan)
kelas 3smp pulsar 180 abu-abu (di beli ama om)
kelas 3smp pulsar 180 hitam (di kasih kakak di bali)
sma kelas 1 CBR600RR (ga enk makenya gila jalan macet pake CBR)
akhirnya skrg ke sekul pake supra xx lebih irit..
(pengen beli fu lagi )
