Remap ECU tanpa pigyback
paidjho
Re: RE: Re: RE: Re: Remap ECU tanpa pigyback
Post by paidjho »
quyquy wrote:
thks a lot om buat infonya..
Bebonk ada mau touring ke surabaya tuh....
Cegat di jalan, kalau gak mau berhenti, kempesin aja ban nya....
[emoji87][emoji87][emoji87]
aldilee18
Post by aldilee18 »
ginting wrote: Fri Feb 24, 2017 23:09 Sayang banget si MuX ini punya ECU merek Transtron Renesas, yg satu satunya di Indo yg make itu merek.
Yg lain pada pake Bosch, Delphi, Denso, Keihin, dll
Sent from my K012 using Tapatalk
jadi ga bisa di remap om? klo gitu colok dastek aja om lsg resing, enak lg nanti jdi ada 5 pilihan map :emo-big_love:
paidjho
Post by paidjho »
SiulTurbo wrote:
fatmike21 wrote:
b8099ok wrote: Fri Feb 24, 2017 8:10 Because rata² "eco car" yg memiliki fungsi sbg daily car dipaksakan menjadi resing daily ultimate weapons,... Dimana "eco car" tsb dipasangi dgn ecu yg ala kadarnya dr pabrikan. Sesuai peruntukannya :ungg:
Rata-rata mobil Honda yg selalu dipaksakan oleh ownernya spy jadi racing... broom brooom :ngacir:
Honda resing ngacir bruuuummmm
Sent from my Redmi Note 4 using Seraya Motor mobile app
Ngerikkkk ada Brioh berpecut.......
[emoji125].................
ginting
Daily Vehicle: ISUZU MU-X
Post by ginting »
Bisa sih...tp tkg kobel kan musti beli alat kobel dan softwarenya...
Trus kalo invest , kapan balek modalnya ??
[emoji3] [emoji3] [emoji3] [emoji3] [emoji3]
fizrmen
Daily Vehicle: Civic FD2
Post by fizrmen »
paidjho wrote: Fri Feb 24, 2017 23:40
kita hijack aja tengah jalan, ANPS or die
2009 Honda Civic FD2
2015 Honda CR-V 2.4l A/T
billyd1773dz
Post by billyd1773dz »
ginting wrote: Fri Feb 24, 2017 23:47
Klw kekeuh mw remap.... D bdg uda bisa tuh...
:beer:
Image Billyd1773dz
Pugman
Post by Pugman »
Mau sharing saja, kebetulan mobil saya mesinnya masih standard tapi sudah remap berkali-kali. Namun karena tidak diukur pakai dyno jadi hanya berdasarkan Feeling saja. Kalau saya gambarkan seperti ini:
1.ECU standar, tarikan bawah lemot, tengah biasa atas lebih enak. Sampai 160kpj suka ga terasa dan mulai berat sampai 190, Konsumsi bbm range 8-10km/ltr.
2. ECU remap1, tarikan bawah bagus, tengah bagus, atas berkurang mencapai 160kpj lebih lama konsumsi bbm 9-10km/ltr tapi kalau cruising dalam kota terasa jerking.
3. ECU remap2, tarikan bawah biasa, tengah biasa, atas bagus sampai 190 lebih cepat baru sempat coba sampai 200 dibatasi oleh keberanian, Konsumsi bbm 9-12kpl.
4. ECU remap3, tarikan bawah sampai atas galak, bahkan dari gigi2 saja cukup lepas kopling pelan2 mobil bisa jalan, tapi kalau dari gigi5 turun ke 4 atau gigi4 ke 3 kopling ga cepat dilepas, mesin pasti mati. Waktu idle juga sering naik turun rpm. Konsumsi bbm 8-10kpl.
Sebenarnya lebih banyak lagi mapping ecu yang saya coba, tapi akhirnya balik ke map yang kedua. namun dari semua mapping yang pernah saya coba, menurut saya remapping itu lebih berguna atau ditujukan kepada penyesuaian gaya berkendara, kondisi lingkungan dan konsumsi BBM. Perbedaan power mungkin ada tapi tidak signifikan dan seperti yang dibilang beberapa suhu disini, remap tanpa merubah mekanikal mesin tetap tidak maksimal. Contoh gampangnya, mau dinaikkan berapapun nilai CO tetap dibatasi besarnya TB secara fisik.
ginting
Post by ginting »
Pugman wrote:Mau sharing saja, kebetulan mobil saya mesinnya masih standard tapi sudah remap berkali-kali. Namun karena tidak diukur pakai dyno jadi hanya berdasarkan Feeling saja. Kalau saya gambarkan seperti ini:
Boleh tau mobilnya merk dan type apa oom ??
Remap dimana oom?
FMEAKD
Post by FMEAKD »
ChZ wrote: Fri Feb 24, 2017 11:26
Taxiberbilio?
Faster than GTI, everything have wheel, si ber behind steering... bisa resiing
Pugman
Post by Pugman »
ginting wrote: Sat Feb 25, 2017 7:48
Remap dimana oom?
Punya saya 406 MT Om, remap sm Om Bobby.
Pugman
Post by Pugman »
b8099ok wrote: Fri Feb 24, 2017 7:52 Maap, knp dimatikan fitur CE? Bahaya atuh,... Thats naughty job klo di remap trus dimatiin CEnya,...
Mobil saya bolak balik remap, CE selalu muncul kalau saya jalan santai antara 1500-2000rpm di gigi berapapun nanti hilang lalu muncul lagi, tapi kalau diatas 3000rpm ga pernah muncul, dugaan sementara karena mobil saya ga ada canisternya sementara software yang dipakai diambil dari tipe coupe yang ada canisternya, tapi karena mesin juga tetap seperti biasa dan ga buat mesin mati atau menimbulkan gejala yang aneh pada mesin akhirnya saya cuekin
b8099ok
Post by b8099ok »
Pugman wrote: Sat Feb 25, 2017 14:20
DTCnya apa? Diliat dl DTCnya, jgn langsung di reset. CE khan sbrnnya cara ecu berkomunikasi dgn driver utk memberi tahu masalah.
FWD + eRWD + 4WD + 4WD = :big_cat:
Yup
hrs dilihat dulu kode DTC dan msg nya apa
Pugman
Post by Pugman »
Turboman wrote: Sun Feb 26, 2017 3:44
Yup
Nah itu dia Om, sudah di check pakai PPS semua normal. Map sensor pernah dipinjamkan yang baru juga ternyata tetap muncul dan Pernah dimapping yang lain ga muncul CE, tapi karena dibawanya kurang enak saya balikin lagi ke Map yang sekarang.
Kalau di MFD ga muncul msg apa2 selama CE muncul. Adanya warning STOP di MFD, dgn msg Coolant Temperatur too high yang sudah ada sebelum remap ecu.
B3M0
Daily Vehicle: Yaris Off-road
Post by B3M0 »
mbah remap mbah..
mbah remap mbah..
mbah remap mbah..
baca 3X dijamin resing
sent from ladies room :e-whistle:
Nainggolan21
Daily Vehicle: Satria FU
Post by Nainggolan21 »
B3M0 wrote: Tue Feb 28, 2017 1:45 mbah remap mbah..
mbah remap mbah..
mbah remap mbah..
Plus tempel stiker bebong, jamin naik 5HP
ngacir ah... ntar ditimpuk :ngacir:
paidjho
Post by paidjho »
Seru juga kalau ngebahas remap atau piggy,
Kalau menurut piyiks sih masing2 punya kelebihan dan kekurangan...
Piggy pro's:
- Ada wujud barang nya
- Bisa jual lagi kalau bosan atau mobil terjual
- Aman walau ada update ecu dr beres
Remap pro's:
- Gak pakai potong kabel
- Parameter banyak, termasuk unlock speedlimit, throttle reponses, close egr, dpf, dll. Dgn banyak parameter, lebih bisa berkreasi lebih luas (tergantung tuner nya jg sihhh)
- Banyak hidden parameter yg gak ada di piggy
Yang perlu diperhatikan:
- Make your plan & preferences, mau konsep drag, street performance, efficient, touring, dll. Effek ke power bandnya mau seperti apa
- Set priority, power or driveability or else
- Ketahui teknologi mobil anda, karena beberapa parameter tidak bisa di control piggy seperti beberapa vnt turbo electronic controlled, dll.
- Ketahui kemampuan & kekuatan mesin mobil, tuner harus nya tahu & mau/bisa memberi tahu
- pastikan tuner bisa tahu dan mengikuti keinginan customer, pas develop map 2gd sampai 6 map sampai mendekati keinginan. Tuner kalo gak bisa ikutin mau kita yaa, pegang pacul aja...
- Manage expectation, dgn stock part, mesin gasoline N/A kira2 naik power 10%, petrol turbo 20-30%, diesel common rail turbo 30-50%.
- Ati2, ce jgn dimatin atau di hide. Coba cabut kabel nya, paling gampang air sensor, ce detect apa nggak?
- Setelah upgrade power, perlu di review untuk upgrade sektor breaking, maintenance, fuel, dll.
Piggy or remap, keputusan masing2, yg penting cari tuner yg bener...
Mohon koreksi kalau ada yg salah....
billyd1773dz
paidjho wrote: Fri Mar 03, 2017 1:48 Seru juga kalau ngebahas remap atau piggy,
Piggy pro's:
Remap pro's:
Piggy yg mana dulu nie.. klw yg seharga remap 2-5jtan memang terbatas.. tp most of them dikelas itu ga pke potong kabel dan plug n play
Tp klw piggy yg canggih dia juga bisa atur bnyk hal yg g bisa dilakukan remap terutama buat modifikasi yg lebih advance hasilny more output juga. kaya switchable map, extra injector, boost non vgt yg masih pke wastage manual, nos, extra injector, bypass keterbatasan stock hardware, ada module *temen2* untuk adjust non computerized component dll.. Boost vnt/vgt sie bisa bngt
Beberapa tuner remap beli mapnya dri tuner di luarnegeri bnyk web yg jual map tune online monggo digugle aja, asal punya alatny bisa upload sendiri mapnya. Versi sana sama dgb indo? Ntah lah.
Ada yg sampai 5cycle untuk tune jarak jauh, proses logging n reflashing to ensure sesuai dgn domestic market (fuel dna spec) ada yg tidak...
Yg pasti klw advance, piggy+remap whynot? Sikat aja keduanya karna keduanya ada +- dan bisa saling ngelengkapi
:beer:
Image Billyd1773dz
b8099ok
Post by b8099ok »
Semua itu selera, n disesuaikan peruntukannya. Utk daily kah? Utk touring kah? Utk nyentul kah? Apa iya mau nyentul utk harian? Depends on the needs,...
Sekali lagi, ini selera masing² orang si empunya kendaraan.
asepcm
Daily Vehicle: ISUZUMUX
Post by asepcm »
b8099ok wrote:Semua itu selera, n disesuaikan peruntukannya. Utk daily kah? Utk touring kah? Utk nyentul kah? Apa iya mau nyentul utk harian? Depends on the needs,...
Noted...
Sent from my SM-G935F using Seraya Motor mobile app
SiulTurbo
Daily Vehicle: Fortuner 2KD
Post by SiulTurbo »
Piggy pro's:
Remap pro's:
gitu ya om, yang bener nih
emang om dah pake dua2 nya
saya lagi binggung nih om
diantara mesin 2GD ANKI yang software ecu nya versi 2200 bukan 2100 saya sendiri :mky_05:
b8099ok
Post by b8099ok »
SiulTurbo wrote: Fri Mar 03, 2017 4:45
Piggy pro's:
Remap pro's:
Resing om,... :ngacir:
lend3
Post by lend3 »
Jd inget video ini, tuning mendapatkan power maximal, akhirnya engine swap. Karena Tuning itu bukan berarti lifetime jadi pendek, sementara kalau maksain pakain enjin bawaan mesin ga awet gampang jebol. Tiap tahun klo ada update exhaust dan ecu, teknologi update. Ya ikut di update jg. Pasang baru.
https://youtu.be/It5-mb32spo
racho
Daily Vehicle: Kawa EX650E
Post by racho »
menarik sekali trit ini...
4G69 bisa remap dimana ya yang 500 rebuan...
paidjho
Post by paidjho »
racho wrote:menarik sekali trit ini...
Pake obd resing yg warna warni..
[emoji125].........
