nnggg.... nganu kok om...ricz wrote:Doekoen Djorok certified....
All New Nissan X-Trail 2015, apakah masuk Indonesia?
Re: All New Nissan X-Trail 2015, apakah masuk Indonesia?
Gusti Allah mboten sare....
Gambar yang lain dari media local
7 seater
dasboard
7 seater
dasboard
- Daily Vehicle: Pleiades
wow ! 7 seater ! desain bagian depan jujur aja gw suka banget ! tarikan garisnya enak diliat..tapi belakangnya...errrr...reminds me with Harrier
interiornya yang warna Beige keren sih, seger ngeliatnya..dan akhirnya Dual Zone Climate Control..palingan begitu masuk Indonesia..sunroof hilang, seat heater hilang, uphill start support + advance hill descend control hilang, 4WD mode hilang, VSC mungkin hilang, airbag sisa 2, HU diganti merk gak jelas, cruise control hilang, headlamp diganti lampu biasa (di luar, yang LED hanya tersedia di versi paling mahal)
tapi baca dari sini http://tinyurl.com/nbxhmpm
hmm..all new Forester 2.0i Premium or all new XTrail ya ?
bakalan kena sunat gak ya yang ini ? palingan fitur no 4 gak dimasukin..mungkin masuk Indonesia akhir 2014 atau awal 2015 kali ya ?Ready to exceed the expectations of compact SUV drivers, four electronic systems have been designed to make life with Nissan X-Trail more comfortable and even safer: two are world firsts and a third is currently found on the premium Infiniti M.
The two world firsts are Active Ride Control and Active Engine Brake. Active Ride Control monitors the road surface to detect undulations which could potentially upset the pitch of the car body and alters the damping to compensate. Active Engine Brake, meanwhile, harnesses the power and controllability of the Xtronic transmission to add a degree of engine braking while cornering or when decelerating to a standstill. The benefits are greater braking control and enhanced feel with less pedal effort.
The third system, pioneered in the premium segment, is Active Trace Control. By using on board sensors to monitor speed, steering angle, throttle opening and braking effort, Active Trace Control brakes wheels individually, as required, to reduce understeer and help the driver steer a safer path through bends: it is particularly effective on slippery, wet roads.
Finally new X-Trail benefits from Uphill Start Support and Advance Hill Descent Control.
#menolaklupa
Mudah2 an VSC yang ndak hilang.. Masaka kalah sama merek CRV yang ada VSC.. heheharistk7 wrote:wow ! 7 seater ! desain bagian depan jujur aja gw suka banget ! tarikan garisnya enak diliat..tapi belakangnya...errrr...reminds me with Harrier
bakalan kena sunat gak ya yang ini ? palingan fitur terakhir gak dimasukin..mungkin masuk Indonesia akhir 2014 atau awal 2015 kali ya ?
Paling gak mahalan dikit gak papa lah, diatas CX5,tapi yang disunat minim..
Mudah-2 baru masuk awal 2016 gan.. baru ambil xtremer 2012 tahun kemarin gan
Yang psti ilang kaya na panoramic sunroof ya wkwkwkw
Tpi semoga aja ga ilang
Ga ada yg d sunat, d jamin keren pasti
kek nya fitur 1-3 terlalu canggih tuh buat di siniharistk7 wrote:wow ! 7 seater ! desain bagian depan jujur aja gw suka banget ! tarikan garisnya enak diliat..tapi belakangnya...errrr...reminds me with Harrier
yg no 4 di crv aja ada, terlalu kalo nissan nyopot juga
tapi positive thinking aja, tuh serena c26 airbagnya 6 biji
Setuju kalo dari pose tertentu, mirip harrier.
Tapi memang dari dulu saya perhatikan, banyak kok produk Nissan yang sosok dan posturnya mengingatkan pada produk2 Toyota
Nih, kalau mau lihat foto2nya lebih banyak lagi. http://www.netcarshow.com/nissan/2014-x-trail/
Jujur aja, ane kok kagak berasa melihat mobil yg keren ya.
Vorsprung durch Technik
The Pursuit of Perfection
From Zero to Hero
Air Tenang Menghanyutkan
Ilmu Padi
From Zero to Hero
Ilmu Padi
Keren atau tidak itu masalah selera.. ,smgandi wrote:Nih, kalau mau lihat foto2nya lebih banyak lagi. http://www.netcarshow.com/nissan/2014-x-trail/
2014 atau 2015 launching gpp.udah pas waktu gantiin t31 ane yg 2010,mantap2,
MUANTAP TAP TAP TAP!asnanblt wrote:Gambar yang lain dari media local
7 seater
dasboard
Luar dalem semuanya dgn design baru dan hasilnya kerennnnnnnn sekaliiiiiii
Ngiler jdnya Setelah sekian lama liat yg kotak sejak gen 1 dan gen 2 yg ngebosenin.
Good job Nissan Tinggal tunggu kapan nih NMI launching disini
Canggih juga nih mobil
Parkir bisa paralel n parkir mall keq vw golf baru
http://m.youtube.com/watch?v=KToD-Q88-lI
Salah post link utube
http://m.youtube.com/watch?v=iwkMlNpXDnI
Lonk diatas fitur lengkap xtrail baru
Hihihi... pantesan yg pertama koq bahas ttg design dari segi designernya.
Yg kedua udh diralat. Abis liat itu, ane makin ngiler berat nih Fiturnya mantap
Thanks bro utk link yutubenya
mantap loh ini...tpi harusnya nissan harus berani bersaing, cx5 aja bisa dibilang komplit fiturnya...ini mesin di jepang sana apa ya?
Nambahin fotonya X-Trail 2014
Mesinnya blm diketahui kalau liat link ini http://www.dapurpacu.com/all-new-nissan ... yenangkan/
FRANKFURT (DP) – All-New Nissan X-Trail tampil perdana di Frankfurt Motor Show 2013. Nissan berjanji akan meluncurkan Nissan X-Trail 2015 mulai kuartal pertama 2014 dan menjualnya pada Juli 2014.
Kini, desainnya lebih modern, menyenangkan dan berotot – tidak lagi terlihat aneh. All-New Nissan X-Trail berbagi platform dengan Nissan Rogue.
Lampu-utama LED dan LED DRL menambah kesan modern. Bagian kabin terasa mahal dengan balutan jok kulit, sentuhan krom dan warna hitam piano.
Dan, X-Trail 2015 dapat memuat 7 penumpang dengan konfigurasi jok 2+3+2. Dengan wheelbase yang lebih panjang legroom dijamin lebih lega.
Nissan menanam sistem keselamatan Nissan Safety Shield. Sedangkan model ALL MODE 4x4i dapat dipilih via tombol putar yang berada di center console.
SUV ini dibekali pula dengan Uphill Start Support dan Advance Hill Descent Control. Dan, di segmennya X-Trail baru ditunjang oleh Active Trace Control – dengan menggunakan sensor-sensor untuk mengawasi kecepatan, sudut setir, bukaan gas dan usaha pengereman – mengerem secara individu untuk menghindari understeer dan membantu pengemudi mengendalikan mobil di tikungan.
Mesin-mesin yang akan diceploskan ke All-New X-Trail belum diinformasikan. Namun, dijanjikan akan lebih efisien, bertenaga, dan tentunya menyenangkan. [dp/Ind]
Modelnya cakep nih, top. Kapan ya masuk Indo?
Kalau masuk Indo makin rame saja nih persaingan medium CUV, ada CRV, CX-5, Xtrail.
Melihat Serena C26 yg dikasih 6 airbags + ada versi panorama roof, semoga NMI juga berani nih kasih fitur2 yang menarik di Xtrail ini. Mantap deh
Tambahin lagi foto yang bukan versi studio, sepertinya ini versi North America:
Kalau versi amrik kayanya mesinnya 2.5L 4 cylinder 170 hp + 175 lb-ft torque dengan CVT. Kalo versi Asia kemungkinan besar bisa sama kali, cmiiw.ola_comoesta wrote:mantap loh ini...tpi harusnya nissan harus berani bersaing, cx5 aja bisa dibilang komplit fiturnya...ini mesin di jepang sana apa ya?
http://nissannews.com/en-US/nissan/usa/ ... all-launch
Buaguss banget cm sayang pantatnya ada cacat desain dikit .
kayanya bakal dateng lagi masa dimana x-trail nyalip crv kaya taun 2005an silam
kalo gak kebanyakan ikut acara sunatan massal
mau nulis apa ya...
Mantap mantap..
CRV ama CX5 patah dah...
2021 Fortuner VRZ
Ini baru keren gak kaya kotak kotak gak jelas di versi sebelumnya....sekarang terlihat modern dan lebih dinamis tanpa meninggalkan kesan kekar dan macho di versi sebelumnya...jika tidak banyak sunat sana sini dijamin menjadi lawan kuat CRV dan akan memaksa Jonpis untuk facelift CRV lebih awal. Bahkan Toyota mungkin akan panas dan memasukkan RAV4 ke Indonesia.
Ini setuju ane mahGilzy wrote:Ini baru keren gak kaya kotak kotak gak jelas di versi sebelumnya....sekarang terlihat modern dan lebih dinamis tanpa meninggalkan kesan kekar dan macho di versi sebelumnya...jika tidak banyak sunat sana sini dijamin menjadi lawan kuat CRV dan akan memaksa Jonpis untuk facelift CRV lebih awal. Bahkan Toyota mungkin akan panas dan memasukkan RAV4 ke Indonesia.
Meski tetep belum bisa beli kalo sekarang
RAV4 ..........dijamin laku dah walau mgkn gak akan selaris CRV , mgkn penjualan 300-400 setiap bulan bisa lah . Cakep banget SUV satu itu . yg kasian cx5 kl udah ada xtrail baru masih ditambah rav4 .
