BMW E36
IndoMild
Re: BMW E36
Post by IndoMild »
Godwill wrote:
poeticmind wrote:oh pantes banyak yg nyari e36... ini sy nyari 3ekor... susah banget, nawarin nya gak sopan harganya... hehe
hrg 2nd e30 & e36 lg naik belakangan ini .. biaya perawatan & onderdil yg masuk di kantong dgn hasil yg memuaskan didukung bengkel spesialis & tk onderdil yg menjamur di kota2 besar
minggu lalu gw nemenin temen beli 320 thn 96, angkatnya lumayan murah 45 jt krn kaki2 dan bagian mesin ada yg perlu diganti tp gak ngebul dan kering knalpot sama mesinnya, gw temenin jg dia ganti2 parts yg dibutuhkan di tk onderdil bmw daerah mangga besar, gw pikir bakal mahal banget harga sparepartnya krn mobil eropa..
pas udh selesai semuanya, gw lumayan kaget ternyata gak semahal yg gw bayangkan, malah gw bandingin dgn camry sodara gw yg thn 2001, jauh lbh mahal camry pdhl mobil jepang.. ternyata omongan org2 ttg sparepart bmw yg mahal banget itu gak semuanya bener krn mgkn mrk bandinginnya bmw dgn yg bkn sekelasnya atau mungkin emang blm pernah punya bmw, gw test drive 320nya uenak banget banget nyetirnya, di tikungan tajam gw geber di 80kpj kagak ngebuang, normal2 aja.. mantap dah
Godwill
Re: BMW E36
Post by Godwill »
Buat bacaan, copas dari http://www.bimmerfest.com/forums/showth ... p?t=205147
A lot of people on the fest ask what mods are best for their bimmer so i thought i would list the most popular ones and describe why they are good for your bimmer. Will put them in order you should do them too.
These include engine performance mods as well as stability etc
This is just my view but will try to be as accurate as possible. Am sure MANY of you will disagree with some of the things that i say, but that is the beauty of a forum. These are compiled from my experiences as a racing driver, test driver as well as an avid Bimmerfest member
1 - Decent petrol
People often go and spend HUGE amounts of money on enhancements or their cars and then use rubbish fuel. E36's are fitted with 'knock sensors' which will advance and retard your timing to sure different octane fuels. The higher the octane of the fuel, the higher the flash point. You want to make sure that the fuel is being ignited in the cylinder at the right time and not any where else. I recommendV-Power 98 RON or at least the highest octane car fuel you can find in your area (US octane ratings work a little different. Not only will you get more power and a more drivable car, but your engine will be cleaner and you also get better MPG.
2 - Good Spark Plugs
Ok, so you have you good petrol being sprayed into your cylinders, now you need to make sure there is a good spark. The OEM plugs are great but improvements can be made for a small cost.
The best plugs out there are NGK IRIDIUM IX plugs. They are brilliant and the affects can be felt right away. The car is smother through the rev-range and pulls better at low revs. They are cheap too and should only set you back around 35GBP ($70).
DONT go for Platinums as they are very problematic and can cause some very strange engine issues. Iridium has a massive melting point and so the electrode gap stays the same no matter how hot or how hard you push your car
3 - Decent Tyres
So often people spend loads of money on upgrades and then put crap tyres on their cars. Remember, your tyres are the only things connecting your car and power to the road and so decent tyres are an absolute must! Tyres are very personal and need to suit your driving style. I always run Pirelli P6000's on my cars as they are perfect for normal driving as well as when i push it. If you want them to last a long time but dont need massive amounts of grip then a hard compound like Bridgestone. If you want lots of grip but dont mind replacing them often then a soft compound like Yokohama is the way to go. There are of course tonnes of others out there!!
4 - CAI (Cold Air Intake)
The most common upgrade for the E36 (and most cars for that matter) is a CAI. A CAI allows cooler, denser air into your engine. Dense air contains more oxygen and the more oxygen you have, the better the bang in your engine leading to more power. The stock airbox on a bimmer is very restrictive and so does not let in the maximum amount of air into your intake. A CAI is a cone filter (such as K&N) with a metal heatshield that replaces the plastic air-box. The heatshield creates a cold pocket of air around the filter that blocks a lot of the heat of the engine. The result is a more powerful (up to 10BHP) and smother engine that also sounds amazing. A good CAI will cost around 150 GBP ($300) but you could get the cone filter without the heatshield for 60GBP ($120) and will still see big gains due to the increased air flow. I recommend K&N
5 - Brakes
Ok, so you have more power by adding the bits above, now you need to stop the flipping thing. An E36 weighs around 1.5 tonnes and so you need some decent brakes to stop it. The OEM brakes are ok but if you need to stop from a high speed in a hurry then you are going to get 'brake fade'. Brake fade is the sporn of all evil and occurs when your brakes get hot. The pedal goes hard and your braking efficiency is massively reduced. You need to install cross drilled discs (rotors) to dissipate the heat caused by the friction as well as some uprated pads. I recommend EBC Green stuffs pads for normal to spirited driving or EBC Red stuffs ceramic pads if you like to really push it or do track days. The increased braking is amazing and brake fade is almost completely eliminated. To get rid of it, you will need to install braided hoses. When your brakes get VERY hot, your brake fluid boils and the standard pipes expand losing efficiency. The uprated discs (rotors) should also stop 'warping' which can be VERY nasty
6 - ECU re-map/chip upgrade
All cars that roll off the production line have to conform to emissions and country laws. They are also made to allow for the worst fuel, the worst drivers, bad servicing and bad weather conditions. Although the ECU is adaptive and so will advance/retard the ignition timing as described above, there is still plenty of power locked away behind your ECU maps. An ECU remap done via your OBC port or a physical replacement of your chip modifies the map to the most efficient possible. This give you lots more power throughout the rev-band and increased MPG as the engine is working at it's best. NEVER EVER EVER add cheap devices that claim to trick the ECU into thinking the air is colder. These are a con, plain and simple. Always go for a well known, reputable companies product. Your ECU is your car's brain and you should never short change it. You would not go to back alley doctor for brain surgery and the same goes for your bimmer. Price is anywhere from 100-300GBP ($200-$600)
7 - Performance exhaust
After fitting the CAI, you will have increased airflow into your engine and it needs to get out. OEM exhausts are restrictive like the intake and so a decent cat-back exhaust will give you more power gains and a lovely sound too. There are many many brilliant companies out there that supply excellent systems for the E36 depending on what you want, what sound you like and how much you want to spend. Prices are anywhere from 100-500GBP ($200-$1000)
8 - Strut Brace
Strut braces stiffen up the geometry of the front and rear suspension giving you a more positive turn in. Prices are around 50-150GBP ($100-$300)
9 - Underdrive pulleys
Underdrive pulleys are smaller and lighter than the OEM ones and reduce the parasitic drag caused by running your alternator. Gains of around 6BHP can be seen with no ill affects to your electrical system. Prices are around 100GBP ($200)
10 - Uprated Engine Bushes
Engine bushes hold your engine in place and the OEM ones can cause the engine to move under hard acceleration/braking and spirited cornering. This increases momentum and can destabilise the car. These stiffen up the engine and stop it moving around so much
There are of course many more out there (including suspension upgrades) but these are the most common and the ones i have the most experience with.
Godwill
Re: BMW E36
Post by Godwill »
BMW Kode busi e36
Bosch: F75DCR
NGK : BKR6EK (standar)
BKR6EQUP (platinum)
BKR6EKIX (iridium)
Denso: K20TXR (standar)
PK20TT (platinum)
IK20 (iridium)
kompresorz
Re: BMW E36
Post by kompresorz »
e36 saya pernah di tawar 100juta..waktu itu taun 2007 saya beli tanah rumah kontrakan n penjualnya lg cari mobil n naksir bmw saya blg lgsg potong aja dr pembayaran..di tawarin mobil lain malah gak mau pdhl jual murah 180juta..disowrom saya jual lebih mahal 185juta..
bos anugrah (asui)bbrp x tawarin mau bayarin mobil saya lebih 20juta dr pasaran tertinggi..
oh ya saya pake iridium denso ik 20 kok lemot ya..saya buang ke saluran air br pake 2-3 jam..
sbenarnya saya naksir punya e46-e90 bosch kaki 4 entah iridium apa platinum...tp kynya gak cocok ulirnya..anugrah bilang malah cepat mati..
kompresorz
Re: BMW E36
oh ya di e36 kampas rem ada yg bunyi gak..saya udah gonta ganti pake belum sampe 500 kilo lgsg ganti ampe saya stok bbrp kampas n piringan di rumah..sampe logo astra bmw jg ada depan belakang..(tekstar,lucas,ate,jurid)...logo astra ada juridn tekstar..
tp sekarang udah ilang setelah pake kampas pagid(hella)..n berasa lebih pakem krn sedikit lebih lebar/luas bekas gigitannya(tar ada area baru gigitannya)..pertama saya pake depan n ilang..setalah itu sekalian ganti belakang(waktu itu belakang belum ada stok)
sampe saya tawarin kampas rem bekas saya di forum bmw..tapi gak ada respon ya udah saya simpan aja taruh di rak garasi..
Godwill
Re: BMW E36
Post by Godwill »
Sy selalu pake iridium ngk, hasilnya memuaskan.. mgkn gak cocok pake denso, di manual booknua memang hanya direkomendasi bosch & ngk, atau salah kode atau palsu.. mau jual brp brake pad?
kompresorz
Re: BMW E36
Saya gak pernah jual barang bekas mobil saya bro godwil..
Saya kasih gratis aja di forum bmw..cm waktu itu gak da yg respon ya udah saya simpan aja..skrg malah saya gak niat lg
Saya pernah kasih 1 set headlam depan n belakang kondisi 99persen kristal dll di forum bmw..ada yg ambil kerumah..
Oh ya saya kurang tau dah soal palsu kebetulan saya beli iridium di salah 1 bengkel terkenal..
Cm saya gak mau tawarin ke forum bmw krn bagi saya itu barang gak bermanfaat..gak enak nanti
richard t
Re: BMW E36
Post by richard t »
kompresorz wrote:
richard t wrote:nice thread bimmers , keren2 bimmers nya Om .
hehhee..hayuk ikutan di pajang fotonya bro richard...gak apa walau seri 5 jg yg penting bmw...sekalian dengan mesin 3.0 hehhe..
awal bulan maret kmarin ada yg bersedia melanjutkan pelihara e34 nya Om Kompresorz , tinggal ada 2foto kenangan + 1dongkrak buaya yg ditekuk sama tuh e34 , Om.
Godwill
Re: BMW E36
Post by Godwill »
http://reviewmobils.blogspot.com/2013/0 ... i323i.html
Merk: BMW
Model: Seri 3 E36 (318i,320i,323i)
Transmisi: Manual 5 percepatan & Otomatis 5 percepatan
Tahun Pembuatan: 1992-1999
Harga Baru: -
Harga Second: 50-83jt (tergantung mesin)
Spesifikasi Kendaraan:
RWD, ABS, EBD, Airbag, ASC (323i only), VANOS (6 Cylinders Only)
1800cc = 115hp & 165Nm, 4 Silinder
2000cc = 150hp & 190Nm, 6 Silinder
2500cc = 170hp & 256Nm, 6 Silinder
Ulasan:
BMW E36, Tak ada kata-kata lain yang bisa dikatakan selain “the ultimate driving machine”, mobil ini adalah bentuk nyata dari keseriusan BMW saat membuat mobil untuk pengendara ( driver’s car ).
Sama juga dengan generasi sebelumnya BMW E30, BMW E36 ini merupakan penyempurnaan dari teknologi serta hasil pada generasi sebelumnya. Seluruh pengamatan serta feedback pengguna BMW E30 ditampung serta jadikan nyata saat membuat BMW E36 ini.
Hasil yang diperoleh bukan satu hal yang biasa, dengan bobot distribusi 50-50 dengan mesin apa pun, mobil ini memiliki handling yang kian lebih spektakular. Mobil ini dapat dibuktikan ketangguhannya dalam balap-balap professional ataupun pemula.
Bukan hanya sekedar itu, mobil ini bisa disebut sebagai seri 3 pertama yang betul-betul nyaman untuk penumpangnya. Dengan area kaki belakang yang cukup serta bagasi yang luas membuatnya betul-betul praktis. Namun mobil ini bukan hanya tanpa kelemahan, model tahun awal ( 1992-1994 ) memiliki masalah pada kualitas interior dengan bunyinya dashboard ( apalagi dari pabrik walaupun ).
BMW E36 merupakan salah satu di antara sedan yang aerodinamis pada musimnya, bila dilihat dari samping tampak garis bodi serta silhouette yang layaknya angin terlebih bila di perhatikan design bagasi yang agak mencuat kebelakang layaknya tersapu angin.
Positif:
Bentuk bodi yang atraktif
Mesin 6 silinder bertenaga
Suspensi pas
Handling yang sempurna- Praktis
Interior sunyi
Negatif:
Kokpit terkesan sempit
Kualitas interior tidak konsisten
Ringkasan:
Tidak ada yang bisa dikatakan selain "Ultimate Driving Machine".
Pendapat ReviewMobils(subjective):
Jika anda hobi dalam berkendara, inilah mobil yang tepat untuk anda. Sebelum memilih mobil lain, saya rekomendasikan untuk mencoba test drive mobil ini dahulu.
Saya pernah memiliki kesempatan untuk mencoba 318i, 320i, dan 323i. ReviewMobils Sangat sarankan untuk mengambil minimal seri 320i. Karena tenaga dengan bobot yang ditawarkan sangat tepat, sebab mesin 1800cc di 318i terlalu kecil dan kurang hidup untuk mobil ini. Saya juga menyarankan transmisi manual jika ingin merasakan semua potensial dari E36.
Kemudian, jika meninginkan mobil ini coba pilih yang diatas tahun 95 atau 320i yang tahun 92/93 yang belum VANOS, karena anda akan dapat merasakan bedanya dan hentakannya tentunya.
Saya tidak bisa mengatakan seperti apa rasanya menggunakan mobil ini. Namun inilah mobil ternyaman dan sempurna dalam urusan handlingnya dari semua mobil yang pernah saya coba. Dan sampai saat ini predikat terbaiknya masih dipegang oleh mobil ini.
Xous
Re: BMW E36
Post by Xous »
Omong2 soal e36, sebenernya slaen om kompre n om goodwill. our boss mr. Tomcat jg pemakai e36 lho, warna merah maroon klo tdk salh hehe. *peace y pak bos.
abrof
Re: BMW E36
Post by abrof »
Haduh kenapa E36 harga bekasnya pada naik ya??? tadinya pingin ngincer yg 320 MT dgn budget max 50jt buat yg kondisinya bagus...gak ada harga segitu. yg 323 MT malah lebih gila lagi harganya
Godwill
Re: BMW E36
Post by Godwill »
abrof wrote:Haduh kenapa E36 harga bekasnya pada naik ya??? tadinya pingin ngincer yg 320 MT dgn budget max 50jt buat yg kondisinya bagus...gak ada harga segitu. yg 323 MT malah lebih gila lagi harganya
e36 terutama m50 & m52 lagi naik daun belakangan ini.. utk thn 90an udh cukup powerful dan dgn handling yg sangat mengesankan membuat skr diburu para peminat bmw.. pengalaman sy e36 yg paling enak utk dibuat modifikasi baik di mesin maupun bodynya serta hrgnya yg tdk semahal seri2 5 & 7.. hrg 2ndnya skr yg dlm kondisi bagus sdh > 55t utk thn2 94-95 , pdhl thn2 sblmnya ada yg mau byr 50jt jg udh sukur... daya tahan sparepart e36 ini cukup awet bisa > 5 thn selama dilakukan perawatan yg normal sesuai manual booknya.. harga sparepartnya bagi sy tdk terlalu mahal mengingat keawetan & hasil yg didapat, boleh diadu hrg sparepartnya dgn mobil2 sekelas thn yg sama spt honda cielo, c200, A4, galant & crown.
klo mau ambil matic utk e36 udh berumur belasan-20 tahunan hati2 krn gak murah biaya sparepart matic & jasanya, bisa berlipat2 hrgnya.. kalau transmisi manualnya gak sampai 2jt udh bisa ganti satu set plat kopling tp jgn di bengkel resmi .. klo om abrof udh ambil, yg pertama2 diperhatikan selain mesin & kaki2 adlh selang bensin, cek apakah msh bagus atau sdh retak2, dan jg kabel2 kelistrikan + kabel2 ac.. ada bbrp kasus e36 yg kebakaran di jalanan & sebagian besar krn mslh di selang bensin yg udh bocor dan kabel2 kelistrikan yg berantakan krn mgkn dulunya hasil modifikasi atau dikerjain montir2 yg gak ngerti ttg bmw... sering kali org lbh perhatikan mesin & kaki2 dulu pas ambil mobil2 yg udh > 10 thn malah kadang suka lupa ttg selang bensin & kabel2 kelistrikan pdhl ini sangat krusial...
Sampai saat ini sy sdh 19 thn memiliki e36 320i M52 dari baru dan bagi sy termasuk best buy yg pernah dilakukan
Di halaman 1 thread ini ada saya copas hal2 yg perlu diperhatikan jika mengincar e36..
Semoga sukses om adorf
kompresorz
Re: BMW E36
hehehe...wah e34 n e36 udah pada pindah tangan..
gmn e60 530 udah bro richard?
kompresorz
Re: BMW E36
oh ya soal review bmw serius bikin e36..kurang tau jg krn gak merasakan e46,e90...apalg f30 belum mampu..
tp saya pernah di tol bintaro-bsd taun 2012 2 hari setelah lebaran agak sedikit nikung kanan lari 160-180 dilibas e46..jauh ketinggalan(e36 saya kalah lg)..5 hari kemudian di tol jelambar-ancol dilibas c200 cgi.. jd e36 saya spesialis kalah mulu..:big_biglaugh: :wkkk: ...
liat f30 lebih ngeri jg..lebar benar bodinya..stabil n kencang... :e-snooty:
Re: BMW E36
Godwill wrote:http://reviewmobils.blogspot.com/2013/0 ... i323i.html
Merk: BMW
Harga Baru: -
Ulasan:
Positif:
Suspensi pas
Interior sunyi
Negatif:
Ringkasan:
Ini kan repiu dr kuskus... :big_chicken:
Re: BMW E36
sbsenernya kalo ane bisa mengingat memori ane taun 2000an saat masi ada 323 manual pengen punya lagi, tapi radiator mleduk bikin trauma, ada yg punya solusi masalah radiator mleduk gini slain ganti utuh? ane pengen punya lagi tapi...... :big_childish: :big_childish: :big_think: :big_think:
kompresorz
Re: BMW E36
Ah dr situ..pantas..bisa2 ktnya lebih sensasi dr w205..
Re: BMW E36
Yg penting jgn sampe Iprit lebi kenceng drpd SLS AMG dah...
:ngacir: :ngacir: :ngacir:
2021 Fortuner VRZ
Re: BMW E36
Pdhl W205 nya blm keluar... :mky_03:
kompresorz
Re: BMW E36
ak4ng wrote:sbsenernya kalo ane bisa mengingat memori ane taun 2000an saat masi ada 323 manual pengen punya lagi, tapi radiator mleduk bikin trauma, ada yg punya solusi masalah radiator mleduk gini slain ganti utuh? ane pengen punya lagi tapi...... :big_childish: :big_childish: :big_think: :big_think:
Solusi sih bnyk kang..cm gak tau benar n awet..
Apa sih yg gak bisa di indonesia..bnyk profesornya kok..
Udah beli aja e36 323 ato sekalian 325 itung2 lebih murah dr avanza..kenangan lama lari 200 serasa nostalgia..cm skrg bawa sendiri..
Tp belinya harus yakin n sambil berdoa sungguh2 dapat barang bagus ya kang..
Re: BMW E36
amiinn... :e-pray: :e-pray: :e-pray: tapi duitnya ud abis duluan buat beli canter uwkwkwk :big_biglaugh: :ngacir: :2gunfire: :snipersmile:
kompresorz
Re: BMW E36
ricz wrote:Yg penting jgn sampe Iprit lebi kenceng drpd SLS AMG dah...
:big_biglaugh: ...kok bisa..iprit mobil apa jin... :big_think:
:big_childish:
richard t
Re: BMW E36
Post by richard t »
Sebetulnya e34 m50 masih sangat enak & joss banget tenaga nya , sangat enak buat lari >150km/h, padahal smua masih standar , bisa minum premium lagi.
e60 530 2009 masih tinggi banget harga nya Om , mirip2 dgn benz s350 w220 2005 , Om.
Godwill
Re: BMW E36
Post by Godwill »
kompresorz wrote:oh ya soal review bmw serius bikin e36..kurang tau jg krn gak merasakan e46,e90...apalg f30 belum mampu..
e46 yg mana dulu bro kompresorz? e46 klo yg msh generasi 1 mesin m43 ane rasa gak mungkin kalah.. tp klo ketemu yg mesin 318i n42, n46 & 320i m54 sulit ngelawan krn scr bhp mrk udh sedikit lbh besar dan bodynya jauh lbh ringan, teknologi mrk pun sdh lbh baik dr e36 .. gak bisa disamain bro.. :D
ane copas dr wikipedia ttg e46 " the body shell of the E46 was claimed by BMW to be 70% more rigid than the E36's and aluminum suspension components were used increasingly in order to decrease unsprung weight. In tune with BMW's core values, the E46 was released with a front engined rear-wheel drive layout with 50/50 weight distribution. This balance allows for optimal handling in regard to the drive train layout" . Jelas kan bro :big_grin:
c200 cgi setau ane mesinnya udh turbocharged blue effieciency bisa menyemburkan power hingga 184bhp ... ya kelaut aja bro ... apalagi kan e36 bro thn 94 dan kondisi mesinnya mungkin sdh tdk seperti msh baru ... yg sekelas dan thn yg sama seperti c200 w202, nah ini baru fair, blm tentu dia bisa lewatin m50/m52 dlm kondisi mesin sama2 normal... ane udh pernah lawan w202 temen ane di jagorawi jam 2 pagi msh jaman kuliah, udh mulai kagak bisa ngejar pas masuk gigi 4...
jgn coba2 ngelawan bmw & mercy jaman skr yg sdh menggunakan sistem efisiensi body dan teknologi mesin yg lbh baik klo gak mau di "kentutin" :big_biglaugh: ... kecuali mesin e36 bro udh di swap ke mesin minimal m30, m60 atau m3 sekalian, pepet aja mrk2 itu :big_grin:
f30 hrgnya jg ngeri :big_biglaugh:
kompresorz
Re: BMW E36
Hehehe..ya saya termasuk penggemar ngebut bro godwil..jd kita tes kira2 dgn seri lain model terbaru msh bisa lawan gak.kan bmw terkenal handling..
Klo kalah saya fair akui..
Cm kdg suka ada anggapan bahwa di seri ini bmw serius bikin.begitu jg anggapan mobil lain..
Saya di dilibas e46 itu adu selipan loh.itu saya yakin e46 lari 200.
Jd dpt pengalaman sendiri seri terbaru terbaik.
