sahabatq8 wrote: Fri May 10, 2024 5:17
Iya kyk di xtrail jg heat exchanger yang menghangatkan oli cvt menggunakan kehangatan coolant tapi kalo coolantnya lebih dingin, mendinginkan cvtf.
Btw pernah coba liat pake obd gak? Kalo mobil om itu biasanya cvtfnya berapa celsius. Kalo di Xtrail Cvtfnya adem, cuma kalo abis nanjak dan rem aja itu CVTF diatas suhu bukaan thermostat 4-5c
ini mobil baru aja abis dipake. everyday dalkot, hampir ga pernah tol. gunung2an jarang.
sahabatq8
Daily Vehicle: Nissan Xtrail
Post by sahabatq8 »
Suryaputra wrote: Fri May 10, 2024 9:22
Omnibus wrote: Fri May 10, 2024 9:12
Suryaputra wrote: Fri May 10, 2024 4:56
Bercanda coolernya mbah
Gak lebih gede dr heatsink prosesor pc gaming ane :big_biglaugh:
heatsink ngana watercooled ngga? :big_biglaugh:
gamer sejati dong kl watercooled
gak segitunya sih wkwkwkwkw
ngerinya bochorr.
Yang penting dingin :weekk:
Opeakkk wrote: Fri May 10, 2024 7:26 Livina L10 om, thn 2010. Tadinya mau pake aisan afw+
Spek bawaannya apa?
Greenhunter
Post by Greenhunter »
sintoni wrote: Fri May 10, 2024 11:41
Spek bawaannya apa?
Livina L10 spek bawaannya nissan matic D yang memang setara dengan dex lll, jadi sdh diisi oli valvoline Dex lll cocok cocok saja, gak usah kepikiran. Lanjut pakai 20.000 km baru flush lagi.
trebla88
Post by trebla88 »
sintoni wrote: Fri May 10, 2024 6:01
Opeakkk wrote: Fri May 10, 2024 5:47 Mbah, kalau Valvoline ATF DEX IIII ini kualitas nya oke ga ? Kemarin ga sempet bawa sendiri, suru driver ke bengkel utk ganti, sy bilang pake aisin AFW+, malah pake valvoline. Bengkel nya rekomen itu, driver sy nurut2 aja 🤦🏻
Mobil apa? Ini ms Dex3 sih cocok buat mobil2 AT yg biasa 4 speed keluaran agak lama.
Lipindut diminta nissan D tapi di march 1.5 minta nissan S yang enceran
Matic sama l10
Bisa pakai dex6
:upss:
Opeakkk
Daily Vehicle: Grand Livina
Post by Opeakkk »
Terima kasih jawaban2 nya 🙋🏻‍♂️🥂
Opeakkk
Post by Opeakkk »
trebla88 wrote: Fri May 10, 2024 14:14
Matic sama l10
Bisa pakai dex6
:upss:
Ini transmisi AT L10 sama March sama persis ya ? Kalau gitu aman2 aja dong pake yg enceran ✌🏻
trebla88
Post by trebla88 »
Opeakkk wrote: Sat May 11, 2024 3:44
Matic sama l10
Bisa pakai dex6
:upss:
Filter strainernya sama
Harusnya sama
Kaya grand livina cvt ama datsun cross cvt sama :upss:
trebla88
Post by trebla88 »
trebla88 wrote: Sun Sep 10, 2023 11:51 Screenshot_20230910_184440.jpg
Serbuk² kotoran
Hitam
Baru ke cakra di bekasi, lipindut L11 kondsi oli oktober 2022 ganti strainer+filter diisi q8 cvt
Km sudah 30rban 11 bulan ya
Hitam legam gini ama banyak gram
Sehari² ngetoll dan dpt di 16.8km/ltr terakhir trek kombinasi
Coba diisi amsoil cvt sekarang, kayanya perlu cvt cooler jg kalau cepet item gini
11 mei
8 bulan nih amsoil cvt
Nempuh 33rb km
Dibuka masih bening :big_weee:
Zkrang diisi shell spirax cvt made in thai
120rb/ltr
Ok nih feel nya sementara
bayp4amd
Daily Vehicle: Xpander Cross CVT 2021
Post by bayp4amd »
Permisi. Mau tanya
Saya ada mobil xpander cross 2021 tapi sudah cvt
Sudah mendekati 20rb km dan mau ganti oli cvt
Apa ada rekomendasi oli cvt yang bagus & comply untuk xpander cvt?
Soalnya oli bawaan pabrik untuk xpander cvt gak jelas, di buku manual disebut cvtf ma1, tapi saya search gak ada yg jual. Kalo ganti di beres mungkin akan ditolak ganti oli cvt krn belum 100rb km
Sekalian tanya adakah rekomendasi bengkel ganti oli transmisi sekitaran depok?
sahabatq8
Post by sahabatq8 »
bayp4amd wrote: Sat May 11, 2024 14:26 Permisi. Mau tanya
Mitsubishi emang agak sesat tuh, manual booknya kopas. Dari Xpander lama Mitsubishi MA-1 , cvtnya jadi ikutan MA-1.
sahabatq8 wrote: Sat May 11, 2024 16:14
Klo lihat manual booknya versi UK, cek di bagian Specification
mitsu lancer pakainya CVTF J1
https://mitsubishi-motors.co.uk/wp-cont ... fmXvIUS3vm
Eclipse Cross pakainya CVTF J4
https://mitsubishi-motors.co.uk/wp-cont ... Manual.pdf
Intinya generasi 2010 mitsu, CVTF nya punya spec CVTF J1
Klo generasi kekinian pakainya J4
Tp kedua hal tsb comply ke spec CVTF di pasaran jaman now.
Jadi emang mitsu indonesia sesat sih manual booknya
Sok copas aja ke forum / mitsu owners club, biar sekalian
dibaca sm PT KTB :big_biglaugh:
bayp4amd
Post by bayp4amd »
Ganti oli dimana om?
Sekali ganti oli cvt dibutuhkan berapa liter untuk xpander?
t105erd
Post by t105erd »
Suryaputra wrote: Sat May 11, 2024 16:28
Mitsubishi motors di dunia lg ngedrop yah kayanya, laku di beberapa negara aja. Untuk truck & bus udah diambil sama daimler saham mayoritas
t105erd wrote: Sun May 12, 2024 0:04
Kondisi serba sulit yah :upss:
bayp4amd
Post by bayp4amd »
Jadi bisa pake J4 om?
Atau ada oli transmisi alternatif selain dari pabrikan?
Kalau ganti merk musti flush kah om?
bayp4amd wrote: Sun May 12, 2024 1:15
Banyak mbah
Cek aja yg comply ke CVTF J4.
Mitsu CVT seri terbaru di seluruh dunia rata2 pakai J4.
Total CVT MV
PTT CVTF
Q8 CVT Evo
Sampai Amsoil CVTF
klo saya pribadi, Cukup drain and refill 2x
Drain and refill 1x juga sah sah aja.
Dalam waktu dekat drain and refill lagi.
Daripada gak diganti samsek :big_biglaugh:
bayp4amd
Post by bayp4amd »
Suryaputra wrote: Sun May 12, 2024 2:00
Banyak mbah
Total CVT MV
PTT CVTF
Q8 CVT Evo
Sampai Amsoil CVTF
Thank you om infonya
Sekali drain & refill untuk xpander kena berapa liter om?
Apa ada bengkel rekomendasi ganti oli transmisi sekitaran depok & jakarta?
bayp4amd wrote: Sun May 12, 2024 2:28
Banyak mbah
Total CVT MV
PTT CVTF
Q8 CVT Evo
Sampai Amsoil CVTF
ke sini aja
https://g.co/kgs/iaPTywi
cakra motor salah satu rekomendasi warga SM.
survey aja dl.
sahabatq8
Post by sahabatq8 »
bayp4amd wrote: Sat May 11, 2024 23:10
Di toko oli TODA bisa. Kalo drain n refill 3liter , kalo mobil yang bisa atf changer cvtnya 8liter.
pisangGoreng007
Daily Vehicle: Xpander Cvt
Post by pisangGoreng007 »
Banyak mbah
Total CVT MV
PTT CVTF
Q8 CVT Evo
Sampai Amsoil CVTF
saya pengalaman 3x ganti, habis nya kurang lebih hampir 3 liter Om.
biasa saya ganti di mbah Marmut, kalau mau ke daerah BSD bisa hubungi beliau...
Sifuyono
Post by Sifuyono »
Misi om2 smua, sebelumnya mohon maaf atas ketidaktahuan dan kebodohan dr saya ini
Kendaraan saya fortuner vrz thn 2018 matic
Mau tanya volume oli transmisi nya berapa liter ya kalo di drain secara normal (bukan dikuras atau flushing)?
Saya menanyakan hal tsb di atas karena saya sendiri bingung volume yg benar pengisiannya seberapa banyak.
Ceritanya begini:
1. Sy drain normal, kluar volume oli bekasnya sekitar 3,8ltr kemudian sy isi dengan oli tmo ws yg baru sejumlah 3,8ltr juga
2. Bbrp hr kemudian sy cek volumenya dgn membuka baut L (baut level oli), saat kondisi mesin idle dan panas. Ternyata oli mengucur keluar sekitar 1,8 liter (sy kaget kok banyak amat ngucurnya). Jadi isi oli barunya skr tinggal 2liter an.
3. Karena takut kurang volumenya, akhirnya sy isi kembali dari oli yg ngucur tadi ke dalam transmisi sebanyak 1,3 liter. Jadi asumsinya skr di dalam oli transmisi ada 2 + 1,3 = 3,3 liter oli transmisi
4. Karena sy bingung takut dan risau, akhirnya saya bawa ke bengkel auto2000 dan disarankan flushing. Berarti sy buang duit sejumlah 1 galon tmo ws.
5. Proses flushing menggunakan 8liter (2 galon ), dan setelah selesai flushing ternyata ada oli sisa 0,5liter dikembalikan ke saya.
6. Setelah itu dipake buat jalan , terasa ga enak, perpindahan transmisi dari P ke R agak alot (keras). Posisi D naik dr 1 ke 2 agak terasa ada hentakan. Kemudian perpindahan dari D ke N jg terasa ada hentakan.
Sekarang saya jadi takut volume oli transmisinya kurang dari standar pabrik (setelah flushing), karena kok transmisinya malah jd ga enak. Saya juga tdk tahu saat flushing olinya diisi berapa liter oli riilnya (kalo dilihat dr sisa oli di kemasan galonnya sisa 0,5ltr asumsi sy diisi 3,5 liter mungkin ya)
Apakah ada cara mengetahui volume sudah sesuai standar pabrik (mungkin ada alat buat scan nya)?
Terima kasih banyak buat sarannya
Opeakkk
Post by Opeakkk »
trebla88 wrote: Sat May 11, 2024 4:02
Matic sama l10
Bisa pakai dex6
:upss:
Harusnya sama
Menarik, tar coba dexron VI sekalian de, pake dulu ini sampe minggu depan ✌🏻
Btw di beres nissan sekarang oli metik nya sedia mobil dexron vi
Chr1stm1
Post by Chr1stm1 »
Sifuyono wrote: Mon May 13, 2024 12:37 Misi om2 smua, sebelumnya mohon maaf atas ketidaktahuan dan kebodohan dr saya ini
Ceritanya begini:
Kalo gejala ada terasa hentakan,umumnya karena kurang oli, top up aja dulu kira2 500ml liat ada bedanya gak.
Sifuyono
Post by Sifuyono »
Chr1stm1 wrote: Tue May 14, 2024 8:51
Ceritanya begini:
Oh gitu ya om
Jadi fortuner vrz ini ga ada patokannya ya volume oli transmisinya berapa tiap x ganti?
